93-98 T100s All T100 trucks
Lifting my 1997 Toyota T100 4wd 3.4L Extended Cab
Old 07-05-2013, 02:23 PM
Scooter1995's Avatar
I can't seem to find a lift kit built for a t100 I want to put a set of 35's on my truck so I was going to lift it 6 inches In The back and 7 in the front. Any ideas? I really would preffer not putting blocks on the leaf springs and turning up my bars in the front.
Old 07-05-2013, 04:39 PM
CJM
CJM's Avatar
Superlift and others still make a kit. Google is your friend. http://www.rockymountainsusp.com/toyota4_T100.htm
You dont want blocks switch to chevy springs or get some springs added to your pack.
Old 07-05-2013, 11:21 PM
Alright will do. I appreciate it.
Old 07-06-2013, 09:43 AM
Zpd426's Avatar
Check out craigslist also if your on a budget. They pop up all the time. I just got one actually
Old 07-06-2013, 04:43 PM
CJM
CJM's Avatar
Also if you can fabricate stuff, pickup a used lift for a the older 86-95 truck off ebay or craiglist. Can modify or use them to build your own lift very easy. T100 uses same front suspension, just wider brackets.
zd92655
03-06-2022 12:58 PM
Weidle
01-21-2019 05:39 AM
5280jo
10
07-13-2015 10:05 PM
Valvoman
06-28-2015 02:45 PM
dirtrider0129
10
06-24-2015 12:24 PM
Quick Reply: Lifting my 1997 Toyota T100 4wd 3.4L Extended Cab
