93-98 T100s All T100 trucks
HELP 1997 Toyota T100 3.4L 4x4
Old 01-15-2014, 11:06 AM
yotaman97's Avatar
I changed out my fly wheel clutch and pressure plate and throw out bearing but my truck will crank with the clutch when its out of gear but it jumps when i try to crank in gear with the clutch down and when it is cranked it wont go into any gears. i cant figure out why ive bled the slave cylinder till their was no air in the lines and nothing is leaking. i cant push the fork that goes to my throw out bearing by hand and when the slave cylinder pushes it it only moves a inch tops. but the slave cylinder is practically new. what else could it be??? is my throw out bearing not installed correctly???
yotaman97's Avatar
i changed the throw out bearing to.
Old 01-15-2014, 11:33 AM
250000_yota's Avatar
Try adjusting the clutch pedal. It sounds like the clutch is still being engaged even though you have the pedal down.
Old 01-15-2014, 11:38 AM
yotaman97's Avatar
i did that to. i cant figure it out. when the truck is off i can push the clutch and go between every gear no problem. but it jumps when you try and crank with it in gear and when you do crank it it doesnt wanna go in any of the gears
Old 01-15-2014, 11:43 AM
Unless the master cylinder is failing, it can't think of anything else that would cause what your describing. I'd say keep trying to adjust it. The clutches on both my trucks start to engage about when I push the pedal 3/4-1 inch down.
Was it doing this prior to the clutch replacement?
Old 01-15-2014, 11:51 AM
yotaman97's Avatar
i cant push the bar conected to the throw out bearing with my hand and the slave cylinder only pushes it back a inch if not less. i unhooked the slav ecylinder its pushing alot farther without being hooked up to the bar connected to the throw out bearing. could my throw out bearing not be hooked up correctly???
Old 01-15-2014, 11:54 AM
Doubtful. The clutch would not disengage at all if you installed it incorrectly.
Old 01-15-2014, 12:14 PM
yotaman97's Avatar
i honestly have no idea what it could be everything was put in correctly
Old 01-15-2014, 12:26 PM
Team420's Avatar
Sure ya didnt install the clutch backwards? I did that in my honda accord once, and same symptoms... took me forever to figure that one out.
Old 01-15-2014, 02:29 PM
yotaman97's Avatar
yeah the way my truck is set up you can only install the clutch one way thank the lord
Old 03-19-2015, 06:55 PM
lenwest's Avatar
no clutch
Did you ever solve your issue?i am a licensed mechanic installed lots of clutch kits and i have the same issue.new clutch kit new master cylinder for the clutch new slave cylinder and new lines.ive tried bleeding numerous times and adjusted pedal and still no clutch.truck lunges when started and cant switch gears when running.any help would be great
Old 03-20-2015, 12:04 AM
wyoming9's Avatar
Red face
Someplace either on the Mechanical parts or Hydraulic you got a wrong part. In the correct box or labeled wrong.
Pretty much any more you need to look at the parts side by side.
It is possible the rubber hose is blowing up under pressure.
Old 03-20-2015, 03:28 AM
lenwest's Avatar
I thought same thing so actually bought a hole new clutch set.figured customer supplied one may have been faulty so have done 2 complete clutch sets.also thought same thing about rubber hose so replaced that too.everything is new except for clutch fork.the pedal dont grab til almost to the floor but does move the fork and bearing about an inch.
Old 04-02-2015, 01:49 PM
BamZipPow's Avatar
What year is yer T-100? Do you have the upgraded clutch pedal support (black) or the original one (rusted/steel colored)? It's possible yer support and firewall is flexing/cracked and isn't allowing full extension of the mechanism. It was common fer the earlier T-100 trucks to have this issue before they fixed the support.
God's Bounty Hunter
07-08-2015 12:54 PM
Jnkml
07-06-2015 01:20 PM
Crazy_Guy97
12
06-24-2015 04:02 PM
Krash
10
07-13-2002 09:21 PM
Quick Reply: HELP 1997 Toyota T100 3.4L 4x4
