93-98 T100s All T100 trucks
EGR Delete problem?
Old 02-10-2013, 12:12 AM
TastyNapalm's Avatar
EGR Delete problem?
I decided to do an EGR delete for my 3.0, everything seemed to go smoothly and there arent any apparent leaks in the exhaust or the intake but it is idling pretty rough now and shot some sparks out the exhaust. I read somewhere that you are required to advance the timing but i cannot find it anymore. is this true? if so how many degrees?
Old 02-10-2013, 03:59 AM
trythis's Avatar
This isnt something that comes up in T100 land as often as in the older pickups (Hilux.)
It might be easier to find info if you disguise yourself as a pickup owner and check that forum.
I looked into this with my 22RE and found it had no benefit, other than making more pollution, so I just cleaned that system out completely and fixed all the sensors and vacuum leaks. After that the truck ran great for a long time. But if EGR delete is your game, I think the Hilux forums will have more info.
Old 02-10-2013, 04:48 AM
bone collector's Avatar
You dont have to advance the timing but these engines like it. I have mine set at 15. Im willing to bet you have a vacuum leak here:
common mistake hope that helps
Old 02-10-2013, 06:57 AM
ksti's Avatar
What I don't understand is the timing thing.
You said you couldn't find it anymore.
I'm assuming you jumped te1 and e1 to check/set timing.
More info
Mine likes 15 also.
Old 02-10-2013, 12:18 PM
I decided to do the EGR delete because the previous owner had welded the bolts to the valve, removed the sensor and bypassed the sensor wire. i figured there was too much going on for me to save, the previous owner had a bad habit of fixing things he didnt know how to fix.
Old 02-10-2013, 12:23 PM
I will go check that now, thanks. And i guess ill advance the timing too, everyone has theirs at 15, i kinda feel left out!
Old 02-10-2013, 12:25 PM
More info
Mine likes 15 also.
I meant i couldn't find the article i read before, that said how many degrees to set timing.
Old 02-10-2013, 12:27 PM
the bolt hole i circled needs to be plugged....
Old 02-10-2013, 12:28 PM
ksti's Avatar
Factory Service Manual 10o BTDC
Old 02-10-2013, 02:50 PM
Alright, i plugged the bolt hole and it runs fine now, adjusting timing now, is the there a vaccum advance or anything i need to unplug before adjusting?
Old 02-10-2013, 03:25 PM
no vacuum advance on the timing, its all electronically based. As long as you jumped the te1 and e1in the diagnosis port when you set the timing, your all set to go. enjoy!!
Old 02-10-2013, 04:42 PM
ksti's Avatar
Good call bone collector
Old 02-10-2013, 05:11 PM
You got it..... ask me how I know.....
Old 02-10-2013, 05:42 PM
Very helpful guys, i appreciate it. ill post some pics soon.
Old 02-11-2013, 07:22 PM
Old 02-12-2013, 09:40 AM
So as i was digging thru my motor, i saw a bunch of vacuum hoses clustered by the alernator and there is a plug un-plugged... i looked at vacuum diagrams and none of them show this (i think)... im not sure what it is or if i want it plugged in!
Edit:
I did relocate these when i took out my air box, they are upside down mounted where the airbox was instead of on the airbox. it was unplugged then also.
ABS maybe?
montanatruck
02-26-2017 07:07 AM
montanatruck
07-25-2015 03:45 AM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Snort
07-09-2015 03:58 PM
Quick Reply: EGR Delete problem?
