93-98 T100s All T100 trucks
95 3RZ-FE head gasket replacement tips?
Old 09-07-2007, 03:49 PM
t100bob's Avatar
are there any special things i should take into consideration when replacing the head gasket on this motor? the engine overheated due to a radiator leak. i've already installled a new water pump and completely flushed, but i was wondering if there were any special tips on cam removal and installation that i should pay attention to?
Old 02-14-2010, 05:19 PM
YellowTT's Avatar
hi,
there are downloadable toyota manuals available here at yota tech. Yes there are several procedures for spring loaded cam removal on the dual overhead setup and special procedures for the torque to yield bolts if reusing old bolts. This is all standard procedure stuff the pain in the A$$ stuff is rusted manifold studs ect. but if your rig does not have allot of rusted bolts it sholdn't be too bad.
Old 08-31-2012, 09:03 AM
lenapralos's Avatar
Make sure you get the head resurfaced. This engine is not as complicated as the 3.0 or 3.4 V6
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
Whatever123
09-30-2015 12:12 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 95 3RZ-FE head gasket replacement tips?
