93-98 T100s All T100 trucks
4Runner to T100 Oil Pan Compatibility?
Old 10-10-2011, 12:59 PM
bigwaterbird's Avatar
I have a 95 T100 5VZFE in dire need of a new oil pan. I can't seem to find a new replacement anywhere (besides the dealer for $200)...but I can find them on Rock Auto for a 96 4Runner (same motor) for a lot less. Of course Rock Auto doesn't show if the two will match up correctly or not. I am just worried the suspension components aren't the same and get in the way somehow...Anyone else run into this before and know the answer? Thanks for any help--
Matt
Old 10-10-2011, 01:58 PM
scuba's Avatar
No they are not compatible. The T100 is a rear sump oil pan where as the 4Runner pan is front sump.
They will both fit the block but they won't clear each other suspensions.
Old 10-10-2011, 02:34 PM
blake.nemitz's Avatar
what about a 3vze pan since its a 95 before the diff side switch, also 3vz was used in the t100 i think
Old 10-10-2011, 05:13 PM
3vze pan...is that why those come up in car-part.com when I search for a pan for my particular engine? Can anyone else confirm this? If so it would definitely solve my problems...
Old 10-10-2011, 08:15 PM
scuba's Avatar
3.0 and 3.4 do share the same block...
Old 10-11-2011, 10:31 AM
if it will clear the diff which if im not mistaken is the same one in the trucks and 4runners of that era. go for it. maybe look at a 4runner or truck parked nearby and see if it is the same as yours. i bet a 3vze pan wopuld be just fine but maybe wait for someone else to chime in
Old 12-29-2011, 08:25 PM
sixstringslut's Avatar
Stupid question, but what happened to your pan that could not be fixed? I have repaired several pans, as long as flange is not trashed, but if that happened block would be trashed as well.
Old 12-29-2011, 09:52 PM
Staff
DeathCougar's Avatar
Matt
88-95 3.0 4WD and 93-98 T100 all use the same pan. You can find an oil pan from an 88-95 3VZE 4WD and its the same as the T100
96-2002 4Runner and 96-2004 Tacoma use a different pan, and CANNOT be used on the T100.
All V6 T100's from 1993-1998 use the same oil pan. They also used the same diff from 1993-1998. The T100 suspension never changed, nor did the differential. In 1995, they switched to the 5VZ which changed the exhaust, fuel system, and even the bed. But not the suspension.
93-94 T100 used the 3VZ
95-98 T100 used the 5VZ
Old 10-03-2012, 11:16 PM
STJ Motorsports's Avatar
I'm looking for a oil pan, oil tube pick up, dipstick tube and dipstick ----
For a 96 T100 truck with a 97 4runner motor needed to swap.
HELP
Old 10-04-2012, 08:03 AM
Staff
HELP
What are you trying to swap the motor into?
Old 10-04-2012, 08:16 AM
The truck is a 96 T100 SR5 4x4 5 speed
The motor is out of a 97 4runner Auto 4x4
I need to swap oil pan, oil pick tube, dip stick and tube
To relocate to the rear. I need to swap the engine harness to fit my T100
ECU. If anyone has a motor harness Toyota part # 82121-34131
I have cash money for you.
Old 10-04-2012, 06:35 PM
BamZipPow's Avatar
Wink
Have you checked on www.car-part.com?
Here's a quick listing...
Year
Part
Model Description Part
Grade Stock# US
Price Dealer Info
1996
Engine Harness Wiring
Toyota T100 WHE 3.4L,AT,4X4 A 8D0081 $400 North State Truck & Auto USA-CA(Red-Bluff) Request_Quote 1-888-283-7770 Request_Insurance_Quote
1996
Toyota T100 3.4L AT 4WD 3-31-11 AN LT1129 $275 LTS Auto Dismantling, Inc USA-CA(Rancho-Cordova) Request_Quote 877-240-8777 / 916-852-7777 Request_Insurance_Quote
1996
Dash Wiring Harness
Toyota T100 2DR,3-96,RWD,BAGS 0G1927 $250 Auto Parts For You, Inc. USA-GA(Canon) E-mail 1-800-790-2504
1996
Dash Wiring Harness
Toyota T100 82135-34040 COWL HARNESS AND FUSEBOX 120029 $200 All Toyota Lexus Parts USA-CA(Rancho-Cordova) Request_Quote 877-247-1717 / 916-638-5555 Request_Insurance_Quote
1996
Toyota T100 ENGINE ROOM HARNESS WITH FUSE BOX 110097 $175 All Toyota Lexus Parts USA-CA(Rancho-Cordova) Request_Quote 877-247-1717 / 916-638-5555 Request_Insurance_Quote
1996
Toyota T100 ENGINE HARNESS 82121-34121 120029 $175 All Toyota Lexus Parts USA-CA(Rancho-Cordova) Request_Quote 877-247-1717 / 916-638-5555 Request_Insurance_Quote
1996
Toyota T100 2.7L MT RWD Z12290 $175 Rancho Toyota Recycling USA-CA(Rancho-Cordova) E-mail 877-551-5575 / 916-631-7777
1996
Toyota T100 3.4L AT 2WD PN 82121-34121 5-4-12 AN TTP $175 LTS Auto Dismantling, Inc USA-CA(Rancho-Cordova) Request_Quote 877-240-8777 / 916-852-7777 Request_Insurance_Quote
1996
Dash Wiring Harness
Toyota T100 A 0F3205 $165 Waterford Truck Dismantling USA-CA(Waterford) E-mail 1-800-544-3488
1996
Toyota T100 TAG 14727,MT,2.7,3-96 A 090116 $150 Davis Foreign Auto Parts USA-AL(Hunstville) E-mail 256-859-0113 / 800-572-7235
1996
Toyota T100 MT 4CYL R09736 $125 Advance Auto Salvage USA-TN(Murfreesboro) Request_Quote 615-896-7700/888-238-9995
1996
Dash Wiring Harness
Toyota T100 SE1487 $100 Auto Wrex Plus USA-ID(Burley) E-mail 1-208-678-7580
1996
Electrical Part Other
Toyota T100 88650-34010 AIR AMPLIFIER 120029 $45 All Toyota Lexus Parts USA-CA(Rancho-Cordova) Request_Quote 877-247-1717 / 916-638-5555 Request_Insurance_Quote
1996
Toyota T100 3.4L,4x4 BATTERY TO STARTER A AA0077 $45 Meadows Bros. Auto USA-MO(Joplin) E-mail 417-623-8877
1996
Toyota T100 A ID2756 $Call Action Auto Wreckers USA-CA(San-Jose) Request_Quote 1-800-606-9732 Request_Insurance_Quote
1996
Toyota T100 5-96,2WD,V6,AC,AT,NEEDS RPR,SEE 07-634 $Call Tony's Auto Salvage USA-SC(Spartanburg) Request_Quote 1-800-964-8669 Request_Insurance_Quote
1996
Dash Wiring Harness
Toyota T100 EXCB,MW,ML,MM,5-96,2WD,V6,AC,AT, 07-634 $Call Tony's Auto Salvage USA-SC(Spartanburg) Request_Quote 1-800-964-8669 Request_Insurance_Quote
1996
Toyota T100 2.7, MT, 2WD 858486 $Call 5 J's Auto Parts USA-NM(Albuquerque) Request_Quote 1-800-456-0065 Request_Insurance_Quote
1996
Dash Wiring Harness
1996
Body Wiring Harness
Toyota T100 A TF3553 $Call Barnette's Auto Parts USA-SC(Sumter) Request_Quote 1-800-669-4095 Request_Insurance_Quote
1996
Toyota T100 3.4L,A,4X4,OK 2 SELL A 9698 $Call ABC Auto Salvage, Inc. USA-NE(North-Platte) Request_Quote 1-800-422-4683 Request_Insurance_Quote
1996
Dash Wiring Harness
1996
Body Wiring Harness
1996
Toyota T100 BNN J065T065 $Call American Pickup Salvage USA-AR(Paragould) Request_Quote 1-870-236-8392 Request_Insurance_Quote
1996
Dash Wiring Harness
Toyota T100 J065T061 $Call American Pickup Salvage USA-AR(Paragould) Request_Quote 1-870-236-8392 Request_Insurance_Quote
1996
Dash Wiring Harness
Toyota T100 649.TO1795, C 250059 $Call A-1 Used Parts USA-FL(Moorehaven) Request_Quote 1-863-946-3535/1-888-946-2234 Request_Insurance_Quote
1996
Toyota T100 2.7,4X2, A496-E $Call All Auto Parts USA-WA(Spanaway) E-mail 253-847-1977 / 800-533-5949
1996
Dash Wiring Harness
Toyota T100 A496-E $Call All Auto Parts USA-WA(Spanaway) E-mail 253-847-1977 / 800-533-5949
1996
Toyota T100 3.4L, 1248p $Call Main Auto & Truck Parts USA-TX(San-Antonio) E-mail 210-932-1100
1996
Toyota T100 02 SENSOR L#200 $Call Fresno Foreign Wrecking USA-CA(Fresno) Request_Quote 559-485-3666 Request_Insurance_Quote
1996
Headlamp Wiring Harness
Toyota T100 A T04T96 $Call Fresno Foreign Wrecking USA-CA(Fresno) Request_Quote 559-485-3666 Request_Insurance_Quote
1996
Toyota T100 2.7L,MFI,RWD,Factory A T04T96 $Call Fresno Foreign Wrecking USA-CA(Fresno) Request_Quote 559-485-3666 Request_Insurance_Quote
1996
Dash Wiring Harness
1996
Body Wiring Harness
Toyota T100 2.7L,AT,RWD,Sail,MW,Airbag,Drive r,Bu A T04T96 $Call Fresno Foreign Wrecking USA-CA(Fresno) Request_Quote 559-485-3666 Request_Insurance_Quote
1996
Toyota T100 2.7,EFI,RWD,Factory RB1685 $Call East Coast Used Parts USA-NC(Clarendon) Request_Quote 877-914-4800 Request_Insurance_Quote
1996
Toyota T100 3.4,AOD,8\95 12C151 $Call B & S Auto Salvage USA-FL(Wildwood) Request_Quote 352-748-1150 / 800-474-1150 Request_Insurance_Quote
1996
Dash Wiring Harness
1996
Body Wiring Harness
1996
A/C Wiring Harness
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Colington
03-08-2020 09:51 AM
Jnkml
07-06-2015 01:20 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 4Runner to T100 Oil Pan Compatibility?
