93-98 T100s All T100 trucks
3400 Oil Pump Repacement
Old 04-13-2008, 05:42 PM
OHRacer's Avatar
Hi All!
I am purchasing one of our old work trucks. It is a 97 T-100 with a 3400 v6 2wd ext cab. It has 200k miles but the oil pump is weak. The pressure has dropped recently and it started to tick so he took in out of service. He had it checked out and was told the oil pump needs to be replaced. Is there any information on how to replace this oil pump? It looks as if the entire front end of the motor has to come apart. Any information on replacement that you all can come up with for me would be great.
Thanks!
Old 04-13-2008, 06:43 PM
BamZipPow's Avatar
Oil pressure is notoriously low fer the 3.4L engine. Best thing to do is to pressure test the pump/oil pressure...stop pulling and guessing.
Ticking could be a sticking valve. Do a leak down test to make sure...
Old 07-18-2017, 02:47 PM
CharleyAce's Avatar
96+ 3400 Oil Pump Replacment Awnsers
Originally Posted by OHRacer
Hi All!
Thanks!
In order to remove the oil pump you must remove the oil pan due to the oil pickup being bolted down. There are two bolts holding the oil pickup in place. Theese two bolts are of the six or so that hold the oil deflection plate to the block. If you are working on a four wheel drive, you must remove the front differential. It's not fun but, can be done. Good luck.
Old 07-18-2017, 07:16 PM
millball's Avatar
If the oil pan must come off, the rod and main bearing shells might be easily replaced then.
It's very likely that the low oil pressure issue falls more squarely on loose rod and main bearing clearances than on the oil pump anyway.
Rod and main shells are very inexpensive, if you're gonna change out the oil pump, put em in.
Old 07-18-2017, 07:48 PM
old87yota's Avatar
^^ It is more than likely bearing clearances. Oil pumps generally outlast the rest of the engine.
BUT, this thread is about 9 years old.
Thread Starter:
Last Activity: 04-25-2008 03:33 AM
Old 07-18-2017, 07:50 PM
millball's Avatar
Wow, I didn't notice. A dead thread indeed.
bigjstang
08-25-2021 12:41 AM
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
Snort
07-19-2015 07:03 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 3400 Oil Pump Repacement
