93-98 T100s All T100 trucks
3.4 pushing anitfreeze out overflow tank
Old 09-24-2012, 03:03 PM
findley87's Avatar
my 95 t100 with 3.4 has started pushing water out overflow tank. I put a new water pump, thermostat, radiator cap and flushed the system. the oil looks fine and the water looks fine could it be a head gasket or cracked? or did I get bad parts?
Old 09-24-2012, 06:19 PM
rworegon's Avatar
If you got decent quality parts it's unlikely they are bad. Were you having this problem before installing these parts? Did you check the thermostat in a pan of hot water with a thermometer to be sure it opens at the proper temp?
Old 09-24-2012, 06:49 PM
ThatGuy1295's Avatar
Ya the the only 2 reseons I know for water coming out of the overflow is:
1. More pressure in the system then the radiator cap is rated for. (which opens up more possibilities, overheating and such)
2. Leaky or bad radiator cap.
Old 09-24-2012, 08:11 PM
rworegon's Avatar
3. Failed head gasket over pressurizing cooling system.
Old 09-25-2012, 04:57 AM
That 3. is just a reseon for 1 to occur.
Old 09-25-2012, 06:24 AM
findley87's Avatar
when I fill it with water and start it the water starts pushing out
Old 09-25-2012, 02:57 PM
If its doing it when cold then id say its reseon 1. caused by reseon 3.
Old 09-26-2012, 06:36 AM
SC T100's Avatar
Did you make sure you burped the coolant system properly so there aren't any air pockets after your re-filled the coolant? Do a quick search, but I believe you need to have the front of the truck pointed uphill and massage the upper radiator hose. There may be another way but it something to look into.
skoti89
09-11-2015 07:46 AM
snekysnake
08-13-2015 02:46 AM
NolaToyota
08-07-2015 10:10 PM
Rkellerman
07-12-2015 08:42 AM
Quick Reply: 3.4 pushing anitfreeze out overflow tank
