Which wire is the ignition wire?
Trying to install a hot shot kit today and I have no idea which wire is the "ignition" wire (1989 22re, 4runner). Can one of you tell me what color the correct wire is supposed to be?
Thank you in advance for your time and help.
Edit: Looked in the only FSM that I can access (1985 year model with the 22re) and it lists an ST1 with a wire that is black with a white stripe and an ST2 with a wire that is brown with a red stripe. I'm guessing that ST1 is the start wire?? I'd prefer to only cut into my wires once.
Edit x2: Mods please delete this post, problem has been solved.
