General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Thinking about doing an h.i.d. projector retrofit on a 2nd gen
Old 12-12-2005, 09:04 AM
Keggo's Avatar
I got them from a guy on HIDPlanet forums. Actually, there's a guy that has some from a Nissan Murano (I believe they're the same projectors that Bratik used from an Infinity FX45) for $125 shipped! BI XENON!! I paid 150 shipped for these. These are from a BMW. Just look in the "Buy, Sell, Trade" forum... there are TONS of projector addicts selling some good stuff.
Praufet's Avatar
Well I feel dumb, that's what happens when you're browsing the forum when you should be sleeping
Old 12-12-2005, 09:05 AM
Keggo's Avatar
Hahahah, don't worry about it.
Old 12-17-2005, 07:32 PM
Keggo's Avatar
Ok, projectors still haven't arrived, but I have all the wires, connectors, relays and everything to make the wiring harnessess. I also bought the new clear lensed headlamps. I was going to go the eBay route, but decided I wanted something that I knew was DOT approved. Anyway, they're made by Pilot and I bought them at Kragen. The lenses are plastic but I've already put them in the oven at 260* F to get the lenses removed and they seem to hold up to heat pretty well. After I'm finished with the mounting of the projectors I'm going to get some 3m headlight protection film... just to further reinforce. I did notice something that may be a problem. The projectors I bought are about 6" long where the headlight housings are only about 4 1/4" deep. So, I'm going to have to take a look in the engine bay to see if there's any room for about 2-4 more inches (depending on the type of ballasts I get... if they have ignitors with bulb holders or something else) of light assembly. Anyway... I started taking pics of the softening the glue to take the lenses off... I did 260* F preheated at 3 minutes per light and it did fine. Wish me luck!
Old 12-18-2005, 10:04 PM
  #25
Silver_Truck's Avatar
you're probably going to run into the stock air box, or get real close..hurry with the pics
Old 12-19-2005, 02:22 PM
  #26
Keggo's Avatar
hahahah... still no projectors... dang usps. I've started wiring because I've decided on ballasts and know exactly what kind of connectors they use... I've also done a little bit of wiring for the solenoids. I'm probably only going to do write ups for the mounting the projectors and give links to the thread(s) that helped me wire it all up.
Old 12-23-2005, 07:47 AM
  #27
Keggo's Avatar
Yess.. Finally got the projectors. I'll take some pics tonight... I have to figure out how to mount them, but, just wanted to let you guys know... it'll be underway shortly!
Old 01-16-2006, 04:17 PM
  #28
Praufet's Avatar
anything?
Old 01-24-2006, 12:42 AM
  #29
914runner's Avatar
What happened here? I plan on throwing Bi-xenon's in my 3rd gen when I get it this week.
Old 01-29-2006, 11:44 PM
  #30
Keggo's Avatar
Ahh... sorry guys... with the baby and everything... stuff is moving kinda slow... I'm just about done with the housings... I'll get some pics up here in a sec...
Old 01-30-2006, 12:20 AM
  #31
Keggo's Avatar
Here you go... here are some progress pics...
Enjoy! The jbweld on the other housing is curing still... but... I hope it all works out! I'll get some pics of the wiring harness... (I've already covered them in split loom though...). Also, for the solenoid for these particular projectors is a little complex. These projectors (Bosch E46 Bi-Xenons) have three wires coming from them instead of two... like other bi-xenon projectors; which makes it more difficult to wire. I overcame a messy bundle of capacitors, resistors and diodes and went with a little pc board to wire all the solenoid powering components together... In short... I wish I had a more simple solenoid scenario... anyway, I've already done everything so... it's almost there! Hopefully by the end of this week, I'll be done!!
Old 01-30-2006, 04:07 AM
  #32
Praufet's Avatar
Freakin' a, that's awesome
Old 01-30-2006, 10:53 AM
  #33
Keggo's Avatar
Thanks! I'm a little concerned as to the length of the whole assembly... The airbox is going to come mighty close... as well as the battery. I may have to leave the lights sticking out just a little bit. But, I'm probably going to form some Lexan Polycarbonate and attach that to my grill somehow to give it a more finished look. I hope I can get it all done by the end of this next weekend...
Old 01-30-2006, 12:42 PM
  #34
yotaman's Avatar
Good job!
Old 01-30-2006, 04:44 PM
  #35
Keggo's Avatar
Dang this stupid wiring for the solenoid... this is really pissing me off...
Old 01-30-2006, 08:23 PM
  #36
sweet!
Old 02-01-2006, 07:03 PM
  #37
Keggo's Avatar
Finally! I made a wiring harness that works everything properly! WOO! Now just some modification to the headlight bracket and I'll be all set to install!!
Old 02-07-2006, 01:39 PM
  #38
Praufet's Avatar
any pics of it all worky?
Old 02-07-2006, 03:15 PM
  #39
Keggo's Avatar
check out the "finished thread".
Old 02-07-2006, 10:00 PM
  #40
midiwall's Avatar
...which would be here:
https://www.yotatech.com/forums/f131/finished-my-h-i-d-retrofit-78186/
Quick Reply: Thinking about doing an h.i.d. projector retrofit on a 2nd gen
