General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
separate rotor from rear end frame on denso alternator
Old 11-07-2011, 09:38 AM
changosurf's Avatar
my haynes manual says that I should be able to completely remove the alternator rotor from both the front & rear housings, by removing a 'thrust washer', and the pictures in the manual show the rotor completely out; Yet I cant separate it from the rear housing, it seems like its either stuck, or the rear bearing is pressed into the housing. How should the rotor be removed? do I need to use a puller or press, or should it just come off with some pressure?
I want to clean up the housings & paint them (masking off the windings of course). Plus, I was thinking about going ahead & replacing the bearings. this is why Im trying to remove the rotor...
Old 11-21-2011, 02:11 PM
changosurf's Avatar
nevermind, I figured it out.
I just needed to tap on the end of the rotor shaft with some force and it slipped right out.
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
steve miller
10-10-2015 01:40 AM
msane99
07-11-2015 08:08 PM
colinmil
07-06-2015 04:03 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: separate rotor from rear end frame on denso alternator
