General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Scan Gauge II
Old 03-06-2007, 07:42 PM
Teotwaki's Avatar
Been meaning to post a picture showing how the Scan Gauge can color match the Toyota display
I used the supplied Velcro tape to mount it right on the column where it is easily watched without being a distraction.
Old 03-13-2007, 12:45 PM
vinmaps's Avatar
Safer!
Originally Posted by skipo
I have the Blend Mount and it doesnt fit over the mirror si I am trying to modify it to fit under the mirror here is a temporary look until I get more time to do it right
Good spot for the Unit...no more dangerous than operating the rear view mirror while driving.
Old 03-13-2007, 01:09 PM
i did the scan gauge group buy, no problem's out of mine. And i second the location on where to put the scan guage, right on the steering wheel.
Old 03-13-2007, 01:13 PM
engifineer's Avatar
I am hearing from some fairly reliable sources that they are working on a new version with USB output for the purpose of datalogging with a laptop. I currently have an AutoTap for my laptop which can do this, but it would be nice and convenient to do it via the ScanGauge as well. I have seen and played around with the SG on a couple of cars and it is a nice little unit.
Old 03-13-2007, 01:37 PM
  #25
midiwall's Avatar
Depending on what you need, there are a LOT of OBD II modules around... I agree that the Scan Gauge II is awesome with the display and the built-in functionality like MPG, but if you're only looking for logging, and/or for a faster refresh rate and extra capabilities, then look into this:
http://www.obdpros.com
I have MANY OBD II boxes - this one is my newest and it's VERY nice. Paul (the designer) didn't use the classic ELM chip, he used a PIC and wrote an ELM emulation mode. As such, he also has a mode that will allow RAW data access to the OBD bus, and the CAN bus. No other box on the market does that - it opens up a LOT of possibilities...
Old 03-14-2007, 10:47 AM
  #26
justinking060310's Avatar
I have the regular Scangauge(I guess it would now be dubbed as Scangauge 1) and it works flawlessly -- I can not say enough about it -- It will monitor pretty much any sensor that the ECM reads. If you want to use the mileage portion make sure you program it to your tank size(duh) --
If you cant picture what mine looks like, it is a box (about 5wx2h) with a cord for obd hookup
Justin
Old 03-14-2007, 02:42 PM
  #27
engifineer's Avatar
I swapped the leds out on one of those for someone once, which was the first one I messed around with. It is a cool little gadget to have, and the new one is great as well.
On programming a PIC to do it.. I have actually thought of doing that, but just dont have the time these days to mess with it. I already have one interface project going that I dont have time to finish... so I figure I shouldnt start another
Old 03-18-2007, 06:33 AM
  #28
AH64ID's Avatar
Originally Posted by Teotwaki
Just picked up my truck yesterday, going to mount it like that for now.
Old 03-18-2007, 07:39 AM
  #29
rdharper's Avatar
Some people never learn, some people learn too much....
Old 03-18-2007, 09:19 AM
  #30
dibble9012's Avatar
Yup, I have one. Wouldn't have bought one when I did but got a GREAT deal on it, so I did It really is nice to have, its very accurate on gas mileage and gallons of gas used, etc. It's nice that it is a code reader too, never had to use that part yet. I highly recommend them!
Old 08-09-2011, 05:41 AM
  #31
cohland's Avatar
Matching the color was good work! What values did you use to get that color?
Thanks,
Chris
Old 08-12-2011, 12:24 PM
  #32
MAD MARK's Avatar
Teotwaki - Those are the same readings I have and the exact same locations haha.
Cohland - You should be able to mess with the color options and have it within a minute close to what you need.
Old 08-12-2011, 12:50 PM
  #33
Fink's Avatar
Thanks,
Chris
I wouldn't expect any replies...this thread is almost 4.5 years old...
Fink
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
zanzabar0
10-11-2015 02:56 AM
Jdgarrison
10-01-2015 05:22 PM
dbollier123
09-29-2015 05:23 PM
Quick Reply: Scan Gauge II
