General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Scan Gauge II
Old 01-07-2007, 11:55 AM
Co-Founder/Administrator
Staff
Corey's Avatar
Scan Gauge II
Who runs one of these?
http://www.scangauge.com/features/
Looks pretty cool, and can do all under the three columns on the above URL.
$169 for all that.
I have to admit, I do not even know where my port is for the OBDII connection.
Somewhere in the cockpit I would imagine.
Old 01-07-2007, 12:39 PM
Elkaholic's Avatar
Hey Corey, theres a deal goin on with Socal Motorsports where you can get them fro $130. Im thinkin Im gonna jump on one of these.
https://www.yotatech.com/forums/show...n+Scangauge+II
Good Times's Avatar
hey ya rookie, did u see this thread?
https://www.yotatech.com/forums/f180/potential-scangauge-ii-group-buy-103058/
Old 01-07-2007, 12:49 PM
Elkaholic's Avatar
YA thats the one I was refferring to. Thats a good deal. Altho I dont know that I really need one I think they are a good buy and can be helpfull when needed at the least. Hey anything for my truck is a good buy HEHE.
Old 01-07-2007, 12:51 PM
Staff
Corey's Avatar
I actually approved that thread before it was posted.
I typed in "scan" into our wonderful search engine, and it did not turn up.
I miss the old days when search worked great.
I may have to get in on the group buy.
Old 01-07-2007, 12:56 PM
Sponsor
Tofer's Avatar
whats up with the search?
Old 01-07-2007, 01:00 PM
Staff
Corey's Avatar
Search on Search, and you will see.
The Search function does not work like it did in the old days.
It does not turn up stuff as easily as it use to.
You have to combine words and phrases together sometimes to get the correct hit.
It has never been the same since we had to rebuild the site several months back.
Old 01-07-2007, 07:17 PM
AH64ID's Avatar
I have only one thing to say about how the search has been working
As far as the SGII.. .download the manual from their site... its a pretty cool toy, and for 130 you cant beat it right now...
Old 01-09-2007, 07:22 PM
L33T35T 4Runner's Avatar
It almost seems like a replacement of those 3000-5000 dollar tools that mechanic shops have to buy
Old 02-01-2007, 04:46 PM
Teotwaki's Avatar
Has anybody looked at a way to nicely mount the unit without resorting to the velcro tabs supplied with it?
Old 02-02-2007, 09:30 PM
Teotwaki's Avatar
I've started digging into the manual and found that you can mix and match your own backlight color. I have managed to concoct a blend that is close to the color in the 4Runner. I have also calibrated the speed using my GPS as a reference on a long stretch of flat highway. Next will be calibrating the gas tank readouts that the MPG is based upon.
Old 02-02-2007, 09:45 PM
Ringmaster's Avatar
Very cool! Might have to pick one up.
Old 02-03-2007, 01:07 AM
Elkaholic's Avatar
Ah man bummer you just missed the group buy
Old 02-03-2007, 03:10 AM
TOYZILLA's Avatar
Scan Gauge II
I was thinking about getting it .Till i seen it only works on 96 an up. I wonder if there is any way to hook up to older than 96 .Like my 89 4runner
Old 02-06-2007, 01:46 PM
Merlin's Avatar
Don't know if you found the answer for this one already, but on the 3G, the OBD port is under the steering wheel, around where your right knee would be, IIRC. It's not too hard to find, and the thing is shaped and pinned so things can only plug in one way.
In the owner's manual for my code reader, it stated something to the effect that (this is not verbatim) that the OBDII port on so-equipped cars must be located in a visible location, not more than ?feet from the steering wheel. Following that, with plug in hand on the code reader, I just looked under the dash until I saw a plug of similar size and shape and gave it a try.
Hope this helps,
Merlin
Old 02-06-2007, 02:38 PM
midiwall's Avatar
HIGHLY doubtful unless you're looking to write code for a PIC or STAMP processor that will collect the data from various sensors on the truck, and spit the data into one of the OBD II protocols.
If you were able to handle that, then you'd be skipping the part were you could plug this in and just display the data on your own.
One thing that would be possible (in theory) is to graft a later-model ECU into your current system. I 'magine that sorting out timing and A/FR signals would be interesting...
Old 02-06-2007, 03:32 PM
Teotwaki's Avatar
4th gen's connector is right near/below the fuse block, left of the steering wheel
Old 02-07-2007, 07:20 AM
mastacox's Avatar
Aren't any of the 1GR 4.0 V-6 [4th gens / 05/06 Tacomas / FJ Cruisers] OBD-CAN, not OBD-II?
Old 02-07-2007, 09:03 AM
Merlin's Avatar
You can find a fairly comprehensive list of CAN-equipped list of vehicles here:
http://www.davisnet.com/drive/products/CANlist06.pdf
Interesting that the 05 4R is listed, but the 064R is not.
Old 02-19-2007, 05:06 PM
skipo's Avatar
I have the Blend Mount and it doesnt fit over the mirror si I am trying to modify it to fit under the mirror here is a temporary look until I get more time to do it right
Quick Reply: Scan Gauge II
