General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
possible afm failure
Old 06-03-2012, 12:43 PM
H2osetd's Avatar
I have a 1990 pick up 22re 2wd, single cab. I just swapped a long block, new distributer, new tps, new fuel filter. I get check codes 24,31,51. Athe truck will start and run for a few seconds and die, sounds like from lack of fuel. I've been trying all I can think. Any help would be great. Reply here or text or call me. 909 557 0199
Thanks ahead of time.
Austin.
Old 06-03-2012, 01:22 PM
ChefYota4x4's Avatar
Check the fuel fuse? Check the pins on the Fuel Pump Connector? Checked to be sure none of the pins in the AFM connector have backed out or are hanging there? Checked the COR? (Not sure if the 90 has a COR... sorry, mostly an 85-87 owner thus far, lol). Have you done the 4crawler fuel pump cheap tricks bypass and otherwise cheap tricks listed? lol>>>>
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
http://www.4crawler.com/4x4/CheapTri...ORelayLocation
Fish around in there and see if you can't rule a few things out with a POE(Process of Elimination)
Gutted91
01-03-2020 09:48 AM
BK2TFUTURE
10-11-2015 08:42 PM
toyotasaurus
09-24-2015 03:30 PM
_Nicco_
09-21-2015 03:06 PM
ErikZ1220
09-10-2015 04:53 AM
Quick Reply: possible afm failure
