No fuel/oil/tach after 22re swap
Just finished swapping an 85 22re into my 84. Engine is running and driving strong iv just got a few electrical issues I can't figure out. Oil pressure, fuel level and tach are not working, and my heater fan only goes on 1 speed. Is it possible I'm missing a ground somewhere under the dash?
I pulled the engine, harness, has tank etc from the 85 and everything was working in that truck
Power coming in and out through the eng fuse, also checked charge fuse. Possible common wire between these gauges that has shorted? Seems odd that a few gauges work though. I'm not the best at electrical...
I have no power running through the yellow/red wire to the tank, before I rip apart my wiring to trace where the power is lost, just want to confirm this wire should have power with ignition on?
steve miller
10-10-2015 01:40 AM
