larger battery or alternator?
I have an M8000 with 2 PIAA 510 4" and 2 65W IPF 900XS lights on a schrockworks bumper on my 3rd gen 4runner. if i have my high beams on and run the fogs and floods and shove the clutch down everything goes dim. I can't imagine what it will do if i have to use my winch at night and i can't keep the rpm's up. So here is my question: Larger alternator or larger/dual batteries? I'm not running any subs or amplifiers, but i do plan on doing a rear bumper build with some bright rear lights mounted within as well as a possible air compressor. any help is appreciated!
Make sure you do some research on the bigger alt. I went with a higher out put 130 amp direct replacement and have to say that I'm not happy while the engine is at idle. As the rpms drop to about idle my lights will dim also.
i have seen the idle switches on the interior but never seen how they have been attached to the throttle, if i knew how to attach i would go that route but i would still want optimum light output while idling.
- http://www.4crawler.com/4x4/CheapTri...leInstallation
Or electronic idle-up:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/13.html
ya just a few washers up top and the wireing is easy
https://www.yotatech.com/forums/f2/c...nstall-209649/
so what i gather is that i can get a higher amp alternator that will bolt on with relative ease but i must add fuses and get a larger gauge wire for this addition?
I bought a high output amp from Maniac Electric. http://www.maniacelectricmotors.com/
They also sell a fused wire to install with the high output alternator.
$180 for everything, and it is a direct bolt in.
To handle the amperage at idle though, you will also need either dual battery set up, or an idle up of some sort. Idle up gives more versatility.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
Bourbonblues
12-15-2017 05:43 PM
justdifferentials
14
06-11-2017 08:36 PM
