General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Help for wiring up key barrel
Old 01-18-2012, 07:29 PM
Adon's Avatar
G'day
I've got a 22R 89 hilux and i want to install a push button start.
From what i can see, i should use wire 4 and 8. tap into wire 4 and run to the 1st prong on button and tap into wire 8 and run to prong 2 on the button.
Would that be the correct procedure? I've attached a pic i scanned from my manual.
Thanks
Old 01-18-2012, 07:39 PM
Leviticus6432's Avatar
I don't think its that easy... youd need a switch panel and a push button
Old 01-18-2012, 07:41 PM
I'd run 3 relays with 2 switches and a button (unless you have heavy duty switches and button)
Old 01-18-2012, 07:45 PM
or if youd prefer you could have a single pole double throw switch... one way is acc middle off and the other way run
Old 01-19-2012, 03:08 AM
Adon's Avatar
I have an aussie made Holden Commodore. I ran the same press button starter switch straight off the back of the barrel. I tapped into a pink wire and a blue or green wire. The workshop manual for that is alot more detailed than the toyota manual i got(both from the same company)
It worked fine for 2years until i removed it to sell the car.
Old 01-19-2012, 04:49 AM
but you would still have to use the key to turn it to acc and run right? seems kinda pointless?
Old 01-21-2012, 05:11 AM
Adon's Avatar
Yeah what you said pretty much. Still able to start with a key. I guess it is kinda pointless. 1 of the keys has the end broken off in the ignition and that key doesnt unlock the doors. I usually leave the broken key in the ignition. I will be installing a basic kill switch in a hidden spot.
Old 01-21-2012, 07:38 AM
sebastianholmes's Avatar
Hey man I had this done to my truck because my kkey tumbler went bad and couldnt find a replacement. I didnt do it, but i know the basics of what he did. You need two switches, one for run, one for Accessory. and then the actualy push button. i wouldnt reccomend it because anyone could get in your truck and drive off without a key.
Old 01-22-2012, 12:13 PM
93NMyota's Avatar
The start circuit has 2 wires that need to go connected if you want at least a push start button. ( not ignition or acc). there are 2 starter wires (pin 1 & 2), for that you need 2 relays. Do not put them together it will work but cause problems! these 2 starter wires are separate for a reason, let me know if you need a relay diagram to get this done, thanks
theking11863
03-19-2016 09:36 PM
gary4runner
09-24-2015 12:53 AM
TDonkey
07-26-2015 10:14 AM
Hamonacracker
07-17-2015 08:33 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: Help for wiring up key barrel
