General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
help with wires in fuel pump!!!!
Old 07-16-2010, 12:39 PM
navy4runners's Avatar
I have a rusted carrier on my fuel pump found one at a yard but i need to cut the wires that connect to the pump and join them , is this posible or its a fire hazard . the wires are ribet to the carrier any ways and they are cover on gass .
Old 07-16-2010, 12:45 PM
I am talking about the wires inside the tank!!!!!
Old 07-17-2010, 09:37 AM
77RogueRunner's Avatar
You can solder the ground wire to the cradle for a good connection. The only risk of explosion would be if there was a spark. For example a loose ground or hot when the pump is juiced that creates an arc. I beleive that a pure current can run through gas with no ill effects, the current just can't cross another. If there is any way to dig the connectors out of the plug (like many Toyota plugs) and re insert them, thay'd be your best bet. Also, talked to the Gardner Bender techs and they don't reccomend any of their shrink tubing to be in a gas bath envoronment.
Old 07-17-2010, 12:57 PM
thanks , I will pull it out and remove the shrink tubes and solder the wires . I will post results later if I dont blow up in the car , hahahahahaha !!
Old 07-17-2010, 05:17 PM
This is serious stuff you're dealing with. If you solder (the gnd), make sure the surface on the cradle is super clean, use lots of flux, and use a propane or MAPP torch to get the cradle up to temp to bond with the solder, then insert the wire into the puddle (flux the wire also). If the metal that the solder is being bonded to isn't hot enough to melt the solder itself, it will not be a good bond at all and may fail someday. Give a few tugs when cool and you should be good....D
Old 07-19-2010, 07:52 PM
I tested today and ran fine , the shrink tubing will hold ok I submerged in gasoline for two days and was fine so i deside to leave it that way until i can find a pump assembly at a salvage , went to work and back total of 2 hours in the road , seems ok . But dont trust it .
Old 07-20-2010, 02:55 AM
PASSLEY's Avatar
I have aproblem with 1kzengine 3ltr tubo diesel.I overhaul the engine recently,but untill now we are not able ro run the engine the egine produce thick witish smoke .We try to replace Injector pump ,still ew face the same problem>I am not sure whow wiring from contol box connected to injector pump.Ca I have asinple wiring diagram from control box whow its connected to the fuel pump
Old 07-20-2010, 02:59 AM
PASSLEY's Avatar
Before the car was using 3l diesel engine .We replace it with 1kz tubo diesel engine .Initiallly wiring system was not carried properly.We fail to start engine properly because we can not trace at fix the wires from contol box to injector pumbp
smthwsn357
05-01-2024 07:28 AM
sandyota
02-04-2021 11:16 AM
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Quick Reply: help with wires in fuel pump!!!!
