headlights/reverse lights kill engine
i have a 94 t100. i have found that whenever i turn on the headlights the truck automatically dies and if i put it in reverse the same thing happens. I have also noticed that the RPM gauge bounces if i put the blinkers or flashers on. Thanks for any help
sounds like your alternator or battery arent supply enough juice, and those lights pull enough amps away from the coil to kill the motor. check your battery first then alternator
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
