General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Fuel pump shutoff switch
Old 04-04-2007, 02:53 PM
Kaleb's Avatar
I know there are many of these threads, but I have yet to find one that has information as to where I can get a hold of a fuel pump wire. If anyone knows of any spots let me know!
Old 04-04-2007, 02:58 PM
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
fuel pump is on top of the gas tank, just look and trace
Old 04-04-2007, 05:32 PM
Kaleb's Avatar
well I cant see anything without taking the tank out. I've done it before, and it is not fun, nor is it easy. Especially with out help, and a full tank.
Old 04-04-2007, 06:34 PM
4Crawler's Avatar
Circuit Opening relay controls the fuel pump, might be easier to get to:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old 04-04-2007, 06:46 PM
according to that diagram, one should be able to place a toggle (or any kind of interrupt switch) somewhere on the ignition relay circuit, like between the ignition fuse and the main relay or between the main relay and its ground, correct? unless I don't see something, this should act as a kill switch for shutting down the fuel system in an emergency, right?
Old 04-04-2007, 06:59 PM
4Crawler's Avatar
CO Relay ground connection would be easy and low current.
CO relay will shut down any time the engine stops (thus letting the AFM close).
Old 04-04-2007, 07:07 PM
I think I'll hit one of the relay grounds with a toggle for a fuel system cutoff switch versus the power wire to the pump. physically where are these relays? ive got diagrams of my particular wiring for it all but I don't know where in the vehicle there are...i wanna say theyre either in or next to the engine-compartment fuse box
Old 04-04-2007, 07:10 PM
4Crawler's Avatar
Might want to read the page I posted a link to, describes the location, at least on the 1st gens. Otherwise, the FSM for your year vehicle should show the relay locations if you look hard enough.
Old 04-04-2007, 07:14 PM
Kaleb's Avatar
I was originally going to tap into the EFI but I could'nt figure out how to open the fuse box. It seems that if I want to put in a switch on the CO relay then I will still have to get to the bottom of the fuse box. Does anyone know how to open the damn thing?
Old 04-04-2007, 07:49 PM
touche. shame on me for not reading first
Old 04-05-2007, 02:54 PM
i just got done putting one in in a hidden location. i ended up doing the FP power wire because of location and convenience. its working just fine thus far.
Old 04-05-2007, 07:30 PM
Kaleb's Avatar
I also just finished doing mine. I decided to go with a relay though. Better safe then sorry.
Old 04-06-2007, 05:11 PM
^VooDoo^'s Avatar
On the 2gen's the COR is passengerside above the ECU.
Old 04-08-2007, 02:59 PM
chopitrakeit's Avatar
harness for pump should run up through floor and along passesger side to a connector by the computer. On my 89 3.0 the fuel pump wire is blue. I know this cuz it broke. lift the plastick door jam plate and roll back the carpet. If you do tap in there, solder nad heat shrink it cuz it gets damp under there esp in winter ( if you live in the snow areas). Also clean up and grease that connector while you have it apart. Mike
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Fundy Rider
07-16-2015 01:35 AM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: Fuel pump shutoff switch
