General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Deck Lamp Switch?
Old 01-24-2009, 10:15 PM
874runner's Avatar
Deck Lamp Switch?
So, i recently discovered that my 4runner was missing the Deck Lamp switch on the left side of the steering wheel. So i hunted one down and installed it, plugged it in. And it didn't do anything... it lights up when i turn it on. but what exactly is it for??? I cannot seem to figure it out. lol
Old 01-24-2009, 10:23 PM
Windsor's Avatar
Did you find the deck lamp in the back? Drivers side, between tailgate and rollbar.
Turn lights and front switch on, then go back to the light and flip the switch on the light.
Old 01-24-2009, 10:27 PM
874runner's Avatar
i believe i tried that. but why would they have 2 switches for one light? doesn't that sound sort of silly? i mean its Toyota here... not hyundai
Old 01-24-2009, 11:05 PM
Windsor's Avatar
If that doesn't work, then you have some diagnosing to do.
Old 01-28-2009, 09:09 PM
874runner's Avatar
yes i think i do. thanks though. i tried that and it didnt work lol
Old 01-28-2009, 09:17 PM
toyota4x4907's Avatar
maybe the bulb is burnt out....
Old 01-28-2009, 09:53 PM
91TPU's Avatar
doesnt work in my truck either, i just figured i had a beat bulb or some chewed up wiring.
Old 01-29-2009, 08:30 AM
4Crawler's Avatar
Deck lamp switch requires the headlights to be on. Then it should work. The reason for two switches is the same reason you have two switches for the same light on a long hallway. Turn the light on at one end, walk to the other end and turn that same light off. Would be a pain to notice you left the rear deck light on (maybe by accident) when you are driving down the road and say turn on your headlights and suddenly notice the light on in back. Instead of having to stop and get out to turn the light off in back, just flip the switch up front. I rewired my front switch to get constant power, instead of headlight power, so I can turn the deck light on any time. Also added an auxiliary 12 volt plug by the rear switch that I can plug an overhead LED light mounted on the roll bar to so I can get some real useful light in back.
Old 01-29-2009, 03:12 PM
874runner's Avatar
thanks i think i replaced the bulb. but i guess i can try again in case i didnt. lol the 12v auxilary is a good idea. i think wiring a inverter to the back and putting outlets in the rear would be good too?
Old 12-01-2018, 07:03 PM
Colby Vankoughnett's Avatar
Diagram
do you have a diagram of the switches ? I have 2 extra I put them in the dash and want to wire light bars to them but I wanted to have a clean Toyota factory look
Old 12-01-2018, 07:46 PM
4Crawler's Avatar
It's just your typical 3-way switch wiring setup. Common terminals on each end (one end to power and the other end to the light). Then two wires connecting the pair of output terminals to each other.
Should be in the Factory Service Manual wiring diagram section. Nearly the last page, next to the radio wiring. If you don't have that, see snapshot below:
https://drive.google.com/open?id=12f...D4cVMJXKs-s78_
More info:
https://www.4crawler.com/4x4/CheapTr...l#DeckLightMod
Old 12-03-2018, 10:35 PM
RAD4Runner's Avatar
Yes, aka Single-Pole, Double-throw switch:
http://www.learningaboutelectronics....ow-switch-SPDT
kawazx636
10-06-2021 03:03 PM
beltcutter
09-30-2015 06:14 AM
PNW94Runner
09-29-2015 02:55 PM
charlie_fong
09-27-2015 10:06 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: Deck Lamp Switch?
