Check engine code 4?????
Well I really need to smog my truck and it's showing code 4 (check engine light).
WATER TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN WATER TEMP. SENSOR SIGNAL
--WATER TEMPERATURE SENSOR CIRCUIT
--ECU
I replaced the temp sensor but that doesn't appear to be what the code calls for. Has anyone else had this code? How do i test the temp sensor? It it constant current or does it only recieve current when warm??? Help...
Thanks
--ECU
Thanks
It goes directly into the harness which seems untouched (huge bunch of tightly wrapped wires). I can't see any way it could be screwed up in the harness. I tried testing the plug which goes into the sensor today with the key in "on" position and neither side had power. Does it haveto be running or warmed up to test?
I'd check fuses first. I doubt that has it's own fuse though. I'd try checking it again at running temp just outta curiosity. If still no response then it's probably in the harness somewhere.
Factory Service Manual has testing procedures, typically a variable resistance related to coolant temperature. If the sender tests OK, repeat the resistance test from the appropriate pins of the ECU connector under the dash. Note that there are 2 or more temperature senders on the engine, which one did you replace (and what sort of engine is this referring to)?
Hey I really appreciate the help. Its on an 85 yota- 22RE. I replaced the coolant sensor for the ECU (in the front of the intake). My hanes has no testing procedures I could find. I should have bought the FSM........
Jnkml
07-06-2015 01:20 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
