General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
22re - Starter click and faint electrical squeal
Old 01-14-2011, 05:45 PM
  #41
1985yoda's Avatar
I had the same exact problem guys. Only difference is the hack I bought my truck from has the wiring so screwed up it doesn't even have the relay on the fender like it used to. So I found the wire at the ignition switch that put out 12V when trying to start and spliced a new wire in and ran it into the connector on the starter. Fixed...I guess
Old 01-14-2011, 05:48 PM
  #42
4Crawler's Avatar
If it is an '85 (going by your user name), there was likely no starter relay from the factory. I know my '85 does not have one, basically a wire from the ignition switch to the starter solenoid.
Old 01-14-2011, 06:07 PM
  #43
1985yoda's Avatar
I don't have the 85 anymore just stuck with the screen name. It's an 86 with a 92 motor and unknown trans. It's just a mess.
Old 01-14-2011, 06:34 PM
  #44
4Crawler's Avatar
Probably better off w/o the factory relay anyway, it is really wired improperly:
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
If the current setup does not work, easy enough to add a dedicated relay.
Old 03-09-2011, 04:01 AM
  #45
KatKrazy's Avatar
I have checked the following ground connections
Battery to chassis
Battery to block
ECU harness to intake manifold
Firewall to head
Is this all the ground points on an 88 22re?
Old 10-18-2015, 10:27 AM
  #46
buckz6319's Avatar
subscriber for reference, since I'm having aome of the symptoms
thanks for the writeup!
chuckross1957
06-28-2019 10:19 PM
clok
08-01-2015 09:42 PM
PlayAwhile
07-20-2015 11:36 AM
Sandman
07-14-2015 12:36 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: 22re - Starter click and faint electrical squeal
