General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
22re no fuel at injectors
Old 09-04-2012, 02:31 AM
  #61
confussed's Avatar
confussed here yes the wires pluged in and yes have a good ground matter of fact i have 4 grounds on this truck one to the valvue cover one to the intake one from my- post to the frame and one from the fender to the battery i have replaced the ECU COIL INGNITER RELAYS FUSESCAP ROTOR BUTTON PLUGS WIRES AIR FLOW SENSOR ALMOST EVERYTHING
Old 09-04-2012, 07:45 AM
  #62
confussed's Avatar
1985 22re efi
confussed here again will i did a noid light test and nothing do i go to the ECU unit and if so how do i check it
Old 09-04-2012, 10:06 AM
  #63
Torlog's Avatar
I had a simular problem on my 89. Make sure you are getting full power to the EFI relay. On mine the EFI fuse had power going across it, but there was corrosion on the out bound side of the fuse. So there was not enough power to open the relay. Something to check i had spark and fuel just no fuel shooting from the injectors. I hope this helps.
Old 09-04-2012, 10:39 AM
  #64
ChefYota4x4's Avatar
Torlog, that's a good point. The kick panel fuse block can even be removed. And even just pulling the EFI fuse and taking a good look couldn't hurt to look for corrosion in the female spade connector inside the fuse block.
Curious; While I know the EFI MAIN relay is VERY rarely bad/can't remember it being the cause for any of this.... It IS testable. I should say they are... The Main Relays.
Wow, Confussed.... sorry to hear, man. Sounds like you've covered most of it. Hope you didn't lose your shorts throwing parts at it.
Testing at the ECU is even in the Haynes... But definitely in the FSM. I've done a couple testings through the system to see if my values are close to the same at the ECU that they are at the units, like AFM, TPS, STA pins, No.10 and No.20 Pins<<<< INJECTOR PAIRS.... Read up on the 'Voltage and resistance testing at the ECU' in the FI Section of the FSM, Confussed... It's free to do. Not sure if by causing a short with or just having one with a bad wire could damage the ECU... but it's VERY rare that the actual ECU goes bad. But, again, IT IS possible. At least testing there you'll find any 'DEAD SPOTS' in the relationship between the ECU and components... Like at the No.10 and No.20 pins..... You can actually see problems at the ECU with 'injector wiring'. Not to mention OTHER wiring, ya know? It helped me to understand things more with my rig by testing the TPS and AFM ....AT THE ECU. Seeing the same resistance values let me know... The wiring between the two was ok/solid/not compromised, most likely.
Old 09-04-2012, 11:28 AM
  #65
confussed's Avatar
Chef could it be my ignition switch acouple months ago i had a problem i went out one morning and all it did was spin over check all fuses and relays then to could it be possible it went out again thats the only thing i havent check ive check the hole wiring harness and no bad wires
Old 09-05-2012, 08:21 AM
  #66
confussed's Avatar
To Torlog and ChefYota 4x4 thanks for the help all that time checking out the wiring harness relays fuses ECM unit vacuum lines went thru this thing over and over again with my eyes open and shut ˟˟˟˟ i think i can get a job now at a Toyota Dealership lmao well any how it mas my FREAKING IGNITION SWITCH YOU ALL CAN PUT THAT IN YOUR BOOK LOL THANKS AGAIN NOT CONFUSSED ANYMORE LMFAO
Old 09-05-2012, 10:16 AM
  #67
Torlog's Avatar
Your welcome for what little help I was. Glad you got her fixed.
Old 09-05-2012, 11:39 AM
  #68
GREAT news, man! My pleasure! Congratz!!!!
Doug4320
03-24-2018 10:11 PM
steve miller
10-10-2015 01:40 AM
pyramid
07-30-2015 10:05 AM
Hiluxtrucha
07-22-2015 10:00 AM
karbin
07-05-2015 11:37 PM
Quick Reply: 22re no fuel at injectors
