1991 pickup no turn signals or flashers
Okay so I have a 90 Toyota pickup and I don't have a y turn signals or flashers when I turn the flasher on the relay activates but no lights when I turn the turnsignals switch the relay makes no noise and I have checked the fuse
Now my thought was that even if there is no lights hooked up shouldn't the dash light come on and if you do have a light or two hooked up they should atleast illuminate. Any help would be great.
Thanks
Thanks
yes I have the fuses that light when blown and I was wondering where is the relay for the turn signals I can't find them in the chilton book so then a thought would be the switches or I am not getting power to the switch
yeah thanks to all that responded but apperently the flasher relay has to work for it to flash went to a junk yard and pulled one out of a 1991 and put in my and walla it worked. the on that i found that i said was working was the silver one on the fuse panel and would click when i turned on the hazzards so i assumed that was the flasher relay and i was wrong so thanks again and i have turn signals. and flashers.
turn signals and hazards
hey man so what did you do to fix them i am having a similar problem? mine specifically is no turn no hazard lights i know all my bulbs and fuses are good relay clicks for both hazard and turn signal switch selection but no lights
You do realize the last post was 13 years ago?
Did you check the fuse for them?
If that's good and they still no worky, check the grounds behind the light unit. The whole thing will pull off, and the ground's behind it. They can get corroded pretty easy. Make sure they're clean, bare metal to clean, bare metal.
Worth a look. I'd check the fuse first, though.
Pat☺
Pat☺
milestone
09-29-2011 06:36 AM
Geographeen
07-11-2007 11:44 AM
not2shabby
02-20-2005 10:26 PM
