Alarm Systems Discussion related to installation, diagnostics, and purchasing of alarm systems
help with install of viper 211HV keyless entry
Old 01-08-2012, 06:11 PM
Chuck 2200's Avatar
Red face help with install of viper 211HV keyless entry
I have a 1995 4 runner and would like to install a viper 211 HV keyless entry. the problem is the instructions are not very detailed. can anyone tell me what wire go's were ? probably should have had it installed but bought it on e-bay and thought how hard could it be. ya i am an idiot.
Old 01-09-2012, 06:16 AM
drpdmazda's Avatar
here are your factory wire colors, hope that helps a little bit, You should only need power, ground, switched ignition, horn honk ( for programming and panic ) dome light if you want to see inside when you unlock, and then your lock wires.
Constant 12V+ White Ignition Switch Harness
Starter Black Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 Black/Red Ignition Switch Harness
Accessory Blue/Red Ignition Switch Harness
Tach Black Diagnostic Connector
Brake Switch Green/White Brake Switch
Trunk Pin Yellow/Black (-) Driver's Kick Panel
Parking Lights Green Driver's Kick Panel or Fuse Panel
Head Lamp Red/White (-) Steering Column
Hood Pin n/a
Factory Disarm n/a
Door Trigger Black/White (-) Connector top of Fuse Panel
Door Lock Blue/White (-) Door Control Relay behind left Front Speaker
Door Unlock Blue/Yellow (-)
Horn Wire Green/Red (-) Steering Column
Old 01-09-2012, 09:13 PM
Chuck 2200's Avatar
Thank you for the info should help
nvdesertrunner
05-11-2020 08:18 PM
jeffold13
09-29-2015 10:31 PM
punks_is_4x4
08-21-2015 01:35 PM
jmyer72
08-20-2015 07:55 AM
Quick Reply: help with install of viper 211HV keyless entry
