Alarm Systems Discussion related to installation, diagnostics, and purchasing of alarm systems
95 4runner viper 3203 install HELPPPPPPP
Old 06-21-2012, 07:21 PM
954x4runner's Avatar
Hi,
the truck is 1995 4runner and im installing a viper 3203 alarm. I found all the wires and hooked everything up BUT the door locks. I found the door lock wires plugged into the relay box behind the driver side speaker.
But i cant figure out which wires from the alarm are supposed to connect to the car.
Ive installed a few viper alarms before but this one is different, being that it has a seperate harness just for door locks with 8 wires. All other dei alarms ive installed just had the simple 2 wire door lock harness with green and blue wires.
here's the install guide ive been using.
can someone PLEAAAASE tell me which wires to connect to the door locks. Everything else seems to work fine.. thanks
Old 06-22-2012, 11:28 AM
drpdmazda's Avatar
h2/1 (violet) & h2/4 (violet/black) go to ground.
h2/5 does your lock (green/black)
h2/2 does unlock (blue/black
its basically a 5 wire relay built in.
Old 06-22-2012, 11:34 AM
Awesome.. Got it squared away thanks sir.
Old 06-22-2012, 12:37 PM
drpdmazda's Avatar
not a problem, and dont forget to switch the parking light fuse, and plug in the antenna before you mount the brain. thats my biggest doh's all the time ha ha
Old 10-19-2014, 09:43 AM
Uniboobtom's Avatar
Thanks for the post. Im going to try an install this week. Wish me luck.
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: 95 4runner viper 3203 install HELPPPPPPP
