what grade fuel do you use?
Originally Posted by TomCham
The only gasoline we have in Hong Kong is Octane 98 US$7.22/gallon
i use 87 all the time, least expensive, but NEVER arco=cheap.
#26
Originally Posted by surf4runner
is this correct? or did you mean 89? i cant even find 93 out here, best is 91 (unles you have a friend at the airport )
....it is crazy over there, they basically sell race gas at all the pumps (you can't get low octane gas, period).
#27
Originally Posted by bob200587
93, almost every time. I'm running some tests on 89, but so far 93 gives me substantial increases in MPG.
#28
MPG
21
18
18
20
18
19
19
17
18
15
17
Grade
93
93
93
93
93
93
89
89
93
93
93
Thats my log to date, I think some of the numbers have been affected by pretty big changes in temperature. I don't even know if you can even read it like it is, but I couldn't upload a Excel file.
Edit: I just showed the Grade and the subsequent mileage. These figures compensate for change in tire size and are about as accurate as can be.
21
18
18
20
18
19
19
17
18
15
17
Grade
93
93
93
93
93
93
89
89
93
93
93
#29
87 octane, mostly Costco gas. No cheap stuff like Arco, Thrifty, etc., etc.
I put the occasional "Lubro Moly" Ventil Sauber(valve clean), "Lubro Moly" Jectron(fuel injector cleaner), Or Chevron fuel injector cleaner every 2-3 gas tank full.
#31
cheapest stuff i can find. just because it's a toyota doesn't mean it needs special gas. my chevy work truck, on the other hand knocks like a snare drum if you mash the gas unless we run 93 in it...then again, it's got a high dollar stroker engine in it...
#33
87, the higher grades are just a waste of money unless your motor uses it specifically, supercharger, or other high performance goodies. I look for the most inexpensive 87 octane I can find.
#36
i run 89 through my 22re, it seems to like it better. my yamaha r6 on the other hand....i run 103 in that baby. cracks like a whip when u grab the throttle. doesnt even compare to 92 or 94.
