What is broken on YOUR Toyota
Old 11-20-2004, 04:45 PM
  #61
roger's Avatar
-latch thingie on one of the ignition coil packs is broken
-wierd engine tick that I've learned to ignore
-a few scratches & dings (expected on a truck w/105k miles)
That's about it. Nothing major.
Old 11-20-2004, 04:47 PM
  #62
AzStorm's Avatar
Mines a little dusty
Old 11-20-2004, 05:40 PM
  #63
Greg_Canada's Avatar
Heh, mine is missing both side panels, the tailgate is being "straightened" (was wavy) no interior except dash and seats, valve cover gaskets leak slightly, needs new shocks, rear leafs sagging, windshield is cracked, needs paintjob (Primer black front panels, bondo to smooth the tailgate and gelcoat white rear panels)...
other than that it's mint.
Old 11-20-2004, 05:54 PM
  #64
Schuey2002's Avatar
.. and mine's a little rusty!!!
(Oh, yeah. I need new tail light housings. The sockets that the bulbs snap into are solid rust.)
Old 11-20-2004, 06:10 PM
  #65
rimpainter.com's Avatar
1. Suspension squeak (not broken, just annoying).
2. Timed "chink" like a rock or something is stuck in one of the hub nut caps.
3. Missing a knob on the rear heater lever.
4. Header cross-under pipe is exposed. I need a cross-under brace welded in.
5. Tracks straight but the steering wheel is slightly to the left.
6. Vibration at 68-72 MPH (really annoying).
Old 11-20-2004, 06:39 PM
  #66
fiveofeen's Avatar
i had a laundry list that was near 2k retail at a garage before i baught mine. everything works fine now and it cost me nearly 650 to fix it all. frt rear brakes, upper and lower ball joints, idler arm, fuel filter, new fluids, shocks,
she is runnin like a friggin champ now!
Old 11-20-2004, 06:55 PM
  #67
BOSTON4RUNNER's Avatar
....just had the joy of putting a starter in today....a real fun job in a 97 3.4 liter
i much rather do a starter on my daily driven truck than the camaro i am about doing buildin....NOT!!!!!!
Old 11-20-2004, 07:34 PM
  #68
NorCalVP's Avatar
Here's mine
97 Taco
Leaking rear diff plug (ripped out on Rubicon in July and sorta put back in)
nagging electrical drain (if i don't drive it every week the batt dies)
Dirtier than a mofo
have new gears and a front ox locker to put in
Bent axleshafts (both rear ones)
need new belts
need to realign OBA compressor
Brakes dive to the right under hard braking
Need to have the colar on the rear driveshaft replaced (got smacked on the Con)
need a new front driveshaft (totally destroyed on the con)
Drivers seat is ripped
need alignment
96 4Runner
rear window button doesn't work all the time
84 Tercel wagon
Leaking valve seals (hopefully going to replace them this week)
never reaches normal temp (i think it's the water pump, i already replaced the T-stat)
cracked windshield, getting a new one on Monday
that's it
Out of all my car's the Taco needs the most work, mostly because i beat the piss out of it. But none of them have ever let me down...
Steve
Old 11-20-2004, 08:42 PM
  #69
Nix_Toy's Avatar
Ok... what's broken on my truck.. hmm.. the whole engine.. oh yea!!
Old 11-20-2004, 08:46 PM
  #70
Keggo's Avatar
-Back up lights don't work
-Sunroof has gone to crap
-Stock Cd player has hardly any volume
Other than that... it's pretty good! But, Mods are soon to come... so, I'll fix those three probs...
Old 11-20-2004, 09:27 PM
  #71
CAM 1's Avatar
Talking
Real bad Radeling (sp) noise from deep in the dash board.
Drive line clunk (axel wrap, Not really broke but anoying none the less).
Well that's about it..............TOYOTA TUFF.....................
Craig.
Old 11-20-2004, 11:56 PM
  #72
Jboy's Avatar
Powered antenna
Starter (recently replaced)
Stud on rear, right wheel
NWOR rear coil springs (recently replaced, thank god!)
That`s it.
Old 11-21-2004, 02:45 AM
  #73
85TurboRunner's Avatar
hmm lets see:
-need to replace head
-need to replace tranny (auto to manual swap)
-bent up front bumper
-need rear bumper
-missing one mud flap
-very loud annoying rattle from the tailgate when accellerating
-various small dents and scratches on body
-rear wiper doesnt work
-rear window switch works when it wants too
-no stereo (stolen last saturday)
-knuckles need rebuilding
-no rear seatbelts
-cracked windshield
-a couple leaks when it rains
-need an alignment
i could probably write a novel on all the things i need and want to fix or replace, aren't 4x4's fun... :pat:
Old 11-21-2004, 08:20 AM
  #74
ASU4runner's Avatar
*Torn CV boots
*A/C Belt (removed)
*Passenger power seat wont budge
*Dented passenger quarter panel (thanks to Daniel at Uwharrie)
*cracked passenger tail-light
*Multiple dents/scratches on rear bumper
*Front bumper looks warped due to many impacts offroad
I think thats all.
Old 11-21-2004, 08:30 AM
  #75
Finebarmaid's Avatar
Not to much is wrong with my 88'.
-drivers side door gets stuck (must slam full body weight on it to open)
-passanger side door (must use two hands simultaneously to unlock
and open)
-needs some interior work not too much though just the doors, &
headliner.
-needs new skins bad (like I'm running bald)
Now the 80' is a whole nother story
-axle seals leak on front so bad it looks like a murder scene.
-shocks are blown (guy that had it before me drilled holes in them, I'm
having a hard time with the mentality behind this one)
-got a few (by few I mean many) small rust issues.
-need to replace one body mount under the cab.
-needs new exhaust from the header back
-needs some tranny work
-no sound system
-as far as A/C goes its not there but thats fine by me.
That would be the short list of my rigs issues. They will all get worked out in their own time.
I did the emergancy break on the 80' last week so it didn't need to be listed as an issue. Starting slow but will have the funds soon to do a lot of the much needed work. Come on salvage yard get me some new donors.
Old 11-21-2004, 09:48 AM
  #76
Keggo's Avatar
Right... I forgot about the power antenna being broken... any advice on what kind I should replace it with? I was looking at the shorter rubber coated ones... but, then again... how is the reception on those???
Old 11-21-2004, 11:38 AM
  #77
kyle_22r's Avatar
*takes a deep breath*
clutch master leaks on the floor
clutch slave is out of adjustment
transmission synchros are going out
shifter needs new side linkage bushings
engine front main seal is gone, low compression, going through a quart of oil every 500 miles
carburetor gasket toasted
front axle seals and knuckle seals are gone
rear axle pinion seal leaks
it'll all be fixed very soon, i get my 22R block back from the shop tomorrow and i'll be buying an L52HD tranny from marlin
Old 11-22-2004, 07:54 AM
  #78
X-AWDriver's Avatar
I can honestly say "nothing" on my '99.
Old 11-22-2004, 07:58 AM
  #79
4RunnerFever's Avatar
Driver's side cv boot. Just replace the passenger side two weeks ago. grrrr
Old 11-22-2004, 07:59 AM
  #80
Do the Taco antenna mod. I just did it and it works great.
The short rubber antennas have horrible reception.
(Not sure if you can do this on a 91 or not...)
Quick Reply: What is broken on YOUR Toyota
