Water Wetter
Old 07-23-2009, 01:03 PM
Ed H.'s Avatar
Water Wetter
My truck had a little bit of a getting hot problem going up steep grades, 33's and stock gears manual tranny, and everything under the hood is good i decided to try out some redline water wetter for my trip to nevada from ca, I made a bunch of climbs the highest to 8000 ft, uphill for about 45 minutes with about 400 lbs in the bed and a passenger, 3rd gear on the wood the whole time and the temp gauge never moved. This stuff is a really good product i definately recomend it.
Old 07-23-2009, 07:18 PM
X-AWDriver's Avatar
Oh yes,I've been using it every car I've owned for the last 10 years.
Old 07-23-2009, 07:35 PM
BT17R's Avatar
+1, pretty much standard fill for amateur road racers.
I stopped using it when Toyota changed to extended life 100K mile coolant though. I don't think that stuff is supposed to be exposed to air.
Old 07-23-2009, 08:01 PM
TurnerR's Avatar
Yep use it in my bike and jeep. cools far better than antifreeze in the summer. In winter I do drain it and replace with antifreeze. Can't beat it in the summer though
Old 07-23-2009, 08:31 PM
Plumbrbob's Avatar
school me I have not heard of this ?
Old 07-23-2009, 08:33 PM
904_runner's Avatar
same here bob, not sure what it does or how it works.
Old 07-23-2009, 08:35 PM
Plumbrbob's Avatar
so i looked it up 19.95 for a 1/2 gal so do I use it straight and dump my anti freeze or mix it with my anti freeze is thier a mix ratio any tricks? do's? donts?
Old 07-24-2009, 07:30 PM
Adam F's Avatar
Its 12oz for $10. 128oz in a gallon.
The 64oz for $19.99 is a premix of regular water and water wetter.
You'd be better off mixing it yourself.
1 12oz bottle treats 3 to 5 gallons of water.
Use 1 gallon to fill your entire system.
Works best with plain water, but I'd mix it with antifreeze, at least in the winter, unless you live somewhere that doest get below freezing.
moparbay
10-06-2015 09:24 AM
puddlepirate
09-29-2015 08:02 PM
Matthew Perez
09-28-2015 05:43 PM
mtrdrms
09-26-2015 07:12 AM
LotOMiles
09-14-2015 11:45 PM
Quick Reply: Water Wetter
