Transmission?? Vibration/Rumble
Old 11-22-2013, 12:13 PM
Bechade's Avatar
Hi All,
First time posting, but I have been visiting this site for years. Great stuff here.
I have a 1996 Toyota 4Runner Limited 4WD with 194K miles. Transmission and drive train seem normal except for one symptom which has stumped me.
There is a loud rumble and strong vibration coming from what I believe is the transmission under very light to neutral load. It is only noticable at highway speeds (above 55 mph or so) and gets worse the faster I am going. At 80 mph the rear view mirror is rendered useless from the vibration. It only occures when I am just starting to give it gas (1st 5% past neutral load or so) or just after all load on the transmission is removed when I let up on the gas. In other words, I have to always either be giving it gas, or have backed off significantly. Otherwise, I get the strong vibration and rumble sound. If I put it in neutral, I can coast just fine without any symptoms. This leads me to believe it is not in the drive shafts, axles, or wheels.
Has anyone ever encountered something similar?
Old 05-07-2017, 02:46 PM
CollinDaniel25's Avatar
Dealing with the same problem currently any chance you figured it out?
TheBFA
02-15-2020 06:55 AM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
Odin
09-26-2015 06:56 PM
toyotasaurus
09-24-2015 03:30 PM
briholt
09-20-2015 10:26 PM
Quick Reply: Transmission?? Vibration/Rumble
