Transfer case sensor? Help!
Old 05-04-2008, 04:56 PM
texcat101's Avatar
I just swapped in a low mileage '87 A340 Auto tranny with a new torque converter to replace my weak original 85 auto. The newer transfer case has a sensor with 2 wires that did not exhist on the older transfer case otherwise it's an exact match. I assume my transmission controller and computer won't even recognize it and maybe I should just unplug it, but I would like to know what it is and how it fits into the big picture. Does anyone know what this sensor is, and why it's not on the '85?
Old 05-04-2008, 05:00 PM
LTrunner's Avatar
usaly there is 1 sensor on the t-case...the 4WD light sensor
Old 05-04-2008, 05:50 PM
texcat101's Avatar
My 85 is not an SR5, very basic pkg I don't think I even have a 4wheel drive light.
Old 05-04-2008, 06:24 PM
Staff
DeathCougar's Avatar
All 4x4's had a 4x4 light
There should be a few sensors in the 87 t-case that are not there in the 85, and I believe it has something to do with the ETC. not 100% sure tho
Old 05-04-2008, 06:35 PM
R.DesJardin's Avatar
Sensors
I know my trans. has two Vehicle Speed Sensors, one on the side of the trans. and one where the speedo gear is at the rear.
Old 05-04-2008, 06:43 PM
texcat101's Avatar
This transfer case has one sensor, perhaps the 85 setup got it's source from the shifter instead of the t'case
Old 05-05-2008, 06:33 AM
mt_goat's Avatar
Got pics?
Old 05-05-2008, 10:06 AM
texcat101's Avatar
Here is a picture thank's for your help
Old 05-05-2008, 10:46 AM
mt_goat's Avatar
Yeah looks a lot like this 4WD indicator switch from a gear driven t-case. If so, it just switches the dash light on.
Old 05-05-2008, 10:57 AM
texcat101's Avatar
I would bet you are right, if my light doesn't work then I will find the circuit and wire it in.
Funny though the 85 must have pulled it's source from the shifter or some other way.
4x4-runner
04-18-2017 09:08 PM
4x4-runner
12-27-2016 01:58 PM
Chumlee780
11-13-2015 03:18 PM
yourrealdad
07-29-2015 11:08 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Transfer case sensor? Help!
