Tranny Identification
Old 10-14-2008, 05:29 PM
gspot's Avatar
cool thx for your help
Old 10-14-2008, 05:34 PM
gspot's Avatar
actually one more question. are the bell housings interchangable? or is the actuall tranny not built for 3.0 or bigger power? thx again
Old 10-14-2008, 11:21 PM
khoopes's Avatar
Thanks for the explanation James. So It sounds like if I want to take a Auto out of a Turbo 4 Runner and put in a W56, I will have to take out the transfer case as well because it is a 23 spline and the W56 is a 21 spline so they cannot work together? Or is the auto a whole different spline??? Cause I thought I could reuse the case. Bummer.
Old 10-15-2008, 09:37 PM
Jay351's Avatar
Im pretty darn sure the bell housings are not interchangable. Not much, if anything will be for the 4cly/v6 transmissions.
The 4cyl transmission is plenty strong enough for the v6. Hell, it will last for awhile in a v8 swapped truck. The r150 is just stronger.. Old toyota = overbuilt!
Old 02-25-2010, 01:49 PM
  #25
StangBanger's Avatar
Originally Posted by JamesD
Only one V6 trans which is the R150 but 2 versions of them. Pre Tacoma 95 and older and Tacoma 95 and up. The input shaft is longer and so it the bellhousing on the Tacoma R150's but other than that they are the same. Of course you have the Turbo 22R trans which has a R151 and gear driven case.
$250 is fair if it works. The easy way to tell if you got an R or a W series trans is look at the bellhousing, if their is 2 holes directly at the bottom of the bellhousing were it bolts to the trans it is a W if none then it is an R.
James
By "directly at the bottom of the bellhousing" do you mean like the attached picture in post#17? The holes on the bottom sides not bottom middle right.. because thats supposedly a 4cyl W series tranny. But i creeped under my 89 3.0 v6 5speed and it too has those two bolt holes on the bellhousing..off to the sides on the bottom
ladybugRC
458
08-21-2020 10:41 AM
TheBFA
02-15-2020 06:55 AM
live4soccer7
05-11-2016 06:52 PM
Davebarbier
11-03-2015 03:28 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Tranny Identification
