Old 02-10-2016, 09:43 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
Print Wikipost
Tire size/gear ratio/speed/mileage
Old 06-18-2010, 11:55 AM
83's Avatar
Every now and then somebody posts these conversions but I can't find where they're getting them from. Basically I want to know how to calculate my actual speed and mileage with off size tires.
Specifically I have 4.10s with 30x9.50 tires, but I'd also like to know what the equations are so I can figure it out for other size tires. Right now though, I'm just trying to get a more accurate gas mileage calculation.
Right now I'm reading about 16mpg, but I know I'm getting slightly better than that since my odometer is thrown off by slightly bigger tires.
Old 06-18-2010, 01:36 PM
tj884Rdlx's Avatar
give a man a fish:
http://www.4crawler.com/4x4/4LoCalc.shtml#MetricTire
teach a man to fish:
when you want to search YT, i recommend searching on google instead. YT's info almost always comes up first anyway (because this site rocks). but you can skim google results and you can't skim YT's. (you have to open the threads)
for this, search "tire size calculator" and "gear ratio tire size toyota"
OR, just go to 4crawler.com and look through there FIRST.
good luck,
Tj
Old 06-18-2010, 02:01 PM
tj884Rdlx's Avatar
i got to putzin' around with tire calculators and found this one, which may interest you. it looks like it also calculates ODOMETER ERROR, which is what i think you need to calc. your correct mileage.
http://www.dakota-truck.net/CGI-BIN/TireCalc.cgi
Old 06-18-2010, 10:25 PM
scuba's Avatar
Tire rolling circumfrence..
OLD / New.
31x3.14 = 97.34 / 33x3.14 = 103.62 = .93
So you would then take you indicated miles traveled and multiply it by 1.093 and that's your actual miles traveled. You then divide actual miles by number of gallons to fill up. This will get you pretty close to approximate.
Old 06-19-2010, 10:34 AM
chopyota's Avatar
Where did the 1.093 come from? I think you may have had a math error. I am pretty sure that should be 1.07. And in that calculation multiplying by pi is unnecessary because it cancels. I think it is easier to use the ratio of the tire diameters multiplied by your mileage.
(new tire diameter)/(old tire diameter) x (odometer mileage)
Old 06-21-2010, 06:05 AM
83's Avatar
Sweet, thanks.
Looks like I'm still getting pretty crappy mileage then. Only really maybe 1mpg better than I thought.
Old 06-21-2010, 09:03 AM
scuba's Avatar
You may be more correct.
I was close
Old 06-21-2010, 09:28 AM
Fossilized
Staff
dropzone's Avatar
this one allows you to play with all kinds of numbers...
http://www.grimmjeeper.com/gears.html
probably already found what you need though
Old 06-21-2010, 10:23 AM
83's Avatar
Thanks OC. I found that one in my searches, but it basically just tells me what my speed is in different gears at different rpms, which is helpful, but doesn't really help with the gas mileage thing.
1uzRunner
63
11-10-2018 03:58 PM
Williamemslie
14
10-05-2015 09:28 AM
AkitaDog
09-03-2015 09:01 PM
128keaton
09-03-2015 05:09 PM
matthew138
09-03-2015 08:21 AM
Quick Reply: Tire size/gear ratio/speed/mileage
