ticking sound after rebuild?
Just looking for some help... I head two burnt exhaust valves so I was running on four cylinders (3vz-e) due to the low compression. The machine shop did a complete valve job and fixed my leak. I put it all back together and the truck runs great, no leaks, good compression everything.. but there is a ticking or knocking sound coming from the head (or valve covers) which ever you prefere to call it. I was wondering if assembly lube was enough for installing the camshaft and the lobes... any help would be aprecciated,,, will this tick go away on its own?
