Starts cold then wont start gremlin 3.4L
Old 02-10-2013, 10:47 PM
Zpd426's Avatar
Ive got a 3.4L from a 98 4runner in my t100 that always starts perfect when cold and runs perfect when running.
Only after sitting about 15-30 minutes after driving it wont start. when its in the in between from warmed up and completely cold.
I have no check engine light and the shop cant seem to make it not start...
In order for me to get it to start I have to wait about 10 or 20 minutes and floor it.. then I have to pump the throttle to rev up the engine because its flooded really bad. But it always starts eventually.
Someone told me either a dirty idler valve or a bad TPS... Any ideas? I am too impatient to search the threads right now. sorry if this has been answered.
Old 02-10-2013, 11:39 PM
brianh699's Avatar
Cold start injector time switch may be bad, if the ecu thinks the engine is cold it will fire the cold start injector and flood it. I don't know the specs for your engine but the switch can be tested with a voltmeter for resistance values at different temperatures.
Old 02-11-2013, 01:20 AM
rworegon's Avatar
No CSI on the 3.4 AFAIK....it was on the 3.0.
Dirty IAC valve on the bottom of the throttle body may be dirty.
How does it run once it starts?
Old 02-12-2013, 11:50 AM
Zpd426's Avatar
Runs perfect, idler valve wont change.ignition though righ?
Old 02-17-2013, 02:44 PM
Zpd426's Avatar
So the shop thought it was the Crank positions sensor which makes sense, I thought this is what it was also... BUT it wasnt the problem... Now we are thinking its some sort of computer problem
bigjstang
08-25-2021 12:41 AM
Doug4320
03-24-2018 10:11 PM
raiderhawks00
07-08-2015 06:23 PM
Huntingtruckcletus
07-08-2015 05:26 PM
karbin
07-05-2015 11:37 PM
Quick Reply: Starts cold then wont start gremlin 3.4L
