Starting issue! Ignitor has no voltage....
Well... I've been racking peoples brains and trying to post for help with minimal luck. After doing head gaskets and manual swap to my 95 4runner V6, she won't start!! The only problem (I hope) is there is no spark. I know there is fuel... Yes I found out the hard way. But my ignitor has no voltage, thus from what I understand there is a wiring problem between the ignitor, ignitor coils and ignition switch. I'm at a loss of what to check or where to look. Has anyone ever had this problem? Any insight? Please help me guys!!
Its possible your ignition fuse is blown or your switch could be bad or you could have a broken wire. You have a good grasp on what your problem is. Your way forward is to grab a FSM or chilton manual and look at the wiring diagram. Trace the circuit out and confirm power or lack thereof along the circuit path until you find where the problem has occurred.
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
Avenged
07-09-2015 07:55 AM
