Old 03-23-2016, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Exterior Guides
Print Wikipost
Show us your best cheap mods!
Old 01-11-2008, 11:02 AM
  #61
flyfishexpert's Avatar
Originally Posted by James Dean
Where did you pick up those lights?
Old 01-11-2008, 12:06 PM
  #62
b.miller123's Avatar
Here's cheapo cup holders, just a couple rolls of tape, if you get the ones that are really sticky on the sides, like gorilla tape (which will hold itself to a vertical surface) they stay in place really good unlesss you move them around alot, they are good for things like the huge drive through cups and cans of soda (esp if your stock cup holders are broken) price: just about free as everyone has duct-tape laying around
it's getto, but it works
Two other things I did:
Hella headlights- way better than old stock lights and easier to change out bulbs, price: about $80
Map lights- out of an SR5, lights up the cab better at night and just plain nice to have, just wire them into the dome light and they work just like they should (when the doors open), price: about $25 off ebay and whatever $$$ for wires
On my old '86 4runner: I wired in a switch for the back window, I put the switch on the plastic "inner bed panel" by the tailgate. It was just nice to have when you sleep back there and you don't have to climb to the front to put the key in and use the switch up there. Sorry as I don't have a write up for this one, I did it about 10 years ago
Old 01-11-2008, 12:38 PM
  #63
Kraeken's Avatar
Wow, a lot of great ideas here!
I'm a photographer and was looking for a nighttime solution to changing lenses and such in the truck while keeping my eyes night adapted.
I replaced one of my maplights with a good quality red bulb. Now I can do stuff in my car like screw around with photo gear and read directions and maps while driving at night without killing my night vision! Its just dim enough, and the other map light is plenty bright when I need it.
Old 01-11-2008, 12:57 PM
  #64
apalmer1's Avatar
I may take pictures later but cheapo mods i have done to my truck:
4.5"deckplate
ECT mod
graywire mod
extended diff breathers
lowered carrier bearing (with washers)
lowered front diff (also with washers)
hardwired power inverter
Old 01-11-2008, 04:03 PM
  #65
James Dean's Avatar
They can be found at trailer or truck supply houses. I have the 10 LED ones but they make 20 LED version that are brighter (more expensive). I cut out the bumper with a die grinder and connected them direct to the reverse lights. Took about 2 hours.
Old 01-11-2008, 05:38 PM
  #66
941uzfetaco's Avatar
On my dads 4runner he put in a autozone ricepipe with k&n filter and a cold air box made out of a 1995 bonnevile door skin (30 bucks). Along with a homemade turbonator (its free but see link below for true turbonator ours works the same way but its cheaper to make your own and helps power alot). A catback 1988 pickup flowmaster exhaust from his wrecked truck (50 bucks when he got it for his truck). Cleaned the intake sensors (free). Ported throttle body (20 bucks by a friend). Cranked the afm 4 cranks (free). Timing advanced 12 degrees (free). Cranked t-bars (free). Used 2in leveling kit in rear (100 bucks). Used 31x10.5x15 ssr intercos on 15x9 american eagle series 058's (150 bucks). Welded factory front and rear 4.10's (free). Removed runing boards (free). Tottal $350 and one good looking and performing truck.
P.S. Heres the link http://www.turbonator.com/
Old 01-11-2008, 08:00 PM
  #67
98sr5tacoma's Avatar
where did you get the maglight holder been looking from is there a link
Old 01-11-2008, 11:23 PM
  #68
stormin94's Avatar
Oh yeah, I also did a custom Mag Lite mount in my 4Runner. It is such a clean install, it actually looks like it belongs in there..............
Here's what I did:
I wedged my MagLite between the driver's seat, and the center console.
That's all.
Total cost: $3.00(Maglite needed new batteries).
Old 01-12-2008, 12:44 AM
  #69
CyMoN's Avatar
extended front & rear diff breathers
2nd front tow hook
back up lights (15$ walmart driving lights)
5$ ebay projector headlights
when I take things apart on the motor I paint the bolts different colors so I know where they go for what part on my 3.0 all the intake manifold bolts are red also make them stick out so I don't miss one when taking it off.
Old 01-15-2008, 06:36 AM
  #70
Squiddy's Avatar
More cheap mods
How about these:
A cabinet to hold stuff (fairly cheap but took a while to fab, etc):
And a tire & jack holder set up:
Old 01-15-2008, 04:56 PM
  #71
Trustyrusty's Avatar
Squiddy, I enjoy your useage of wood on your truck, my grandfather did similar things to his van athough, he was a carpenter..
The following users liked this post:
Rhoffman (12-27-2019)
Old 01-15-2008, 06:34 PM
  #72
Squiddy's Avatar
TR
Thanks! Or should I be wounded that I am not a carpenter !?
Old 01-15-2008, 07:20 PM
  #73
fast7mtoys's Avatar
um where do i start, i removed my bumper and switched the plugs for the clear corners to the turn signals, lincoln locked the rear diff, extended the diff breathers, converted my ac pump to an air compressor, made "spotter friendly" lights out of my old blinker housings, (i have hid headlights and when wheelin with other people they allways complain!!!!) custom made center console with 8in sub and cd mp3 player inside, 1/2 doors, custom led tail lights(tired of replacing lenses) flat black super easy to take care of paint (no scratches here!!!) hillbilly super thermostat mod (cardboard in front of radiator) axillary fuse block, toggle switch for ecu power (anti theft device!!!) gas tank and battery in the bed, (makes a whole lot more room under the truck with the tank in the bed!!!) home made super beefy rear shackles, home made sliders, self built grant wheel adapter, bunch more just cant think right now
you can see one of my "spotter friendly" lights in the pic the other one came loose on the trail so i removed it (they are both back on now)
Old 01-15-2008, 07:33 PM
  #74
4runnerguy's Avatar
thats sweet fast7mtoys do u got pics so u can post up
Old 01-15-2008, 07:47 PM
  #75
johnsenpa's Avatar
Found some free scrap steel and and the rest was just time and patience, but it is different and I like it, and best of all it gave me alot of precious tim spent with ole blue!
Old 01-15-2008, 07:59 PM
  #76
toylocost's Avatar
Location: Yotatech, because Pirate is too expensive. NorCal.
Originally Posted by Squiddy
How about these:
So the lock is screwed onto the wood. Dont that kinda make the lock useless? lol
Old 01-15-2008, 08:02 PM
  #77
fast7mtoys's Avatar
i have a few not too may though i need to take some!!!!!
guess i should just do a build page
Old 01-15-2008, 09:19 PM
  #78
nick_8787's Avatar
Removed the running boards. $0. Looks like it got a small lift.
Old 01-16-2008, 03:01 AM
  #79
CyMoN's Avatar
I also installed a sunpro tach that was a pretty cheap mod and worth doing
Old 01-16-2008, 03:59 AM
  #80
Squiddy's Avatar
Fast7MToys -- how about showing us that custom center console, as I need some ideas
Dirtbiker -- if you look at the picture, the screws are actually "one way" so they can't be screwed out. But hell, I live in Boston so I don't keep especially valuable stuff in the truck anyhow...
Quick Reply: Show us your best cheap mods!
