Seafoam Injector / Intake Cleaner = GOOD STUFF
Old 06-24-2004, 10:58 AM
  #81
keisur's Avatar
Well, my mileage is bad mostly due to my 285's and 4.88 gears.
keisur is offline
Old 06-24-2004, 05:44 PM
  #82
Ric
Banned - User requested
Ric's Avatar
re
well i tried the seafoam tonight, and i didnt get any white smoke from the tail pipe, nor did the rig act like it wanted to die, so i stoped at about 1/3 of the can, let sit for about 5-8 min.s poured the rest in tank, and drove to fill her up, we will see if i get better MPG
Ric is offline
Old 06-24-2004, 06:05 PM
  #83
keisur's Avatar
doesn't sound like you did it right. sounds like you just dumped it into the gas tank.
keisur is offline
Old 06-24-2004, 06:36 PM
  #84
midiwall's Avatar
I didn't get any white smoke after the 5 minute rest either. But I _did_ get it when I started it up the next day.
Like Keisur asked, you did pour it into the PCV line, right?
midiwall is offline
Old 06-24-2004, 06:57 PM
  #85
Ric
Ric's Avatar
re
oh no, i pulled the PVC out and poured 1/3 can into the motor,,, now im freaking, it was suppose to got int the "line" ??? oh ˟˟˟˟, i hope i didnt mess anything up,, it did run fine, when i went to fill up the tank,, think i messed up the motor ????
sometimes i feel like such an IDIOT
Ric is offline
Old 06-24-2004, 07:00 PM
  #86
Ric
Ric's Avatar
do you think i should. try to do again BUT this time pour it into the "PVC line" or should i even worry about it, seems to be running fine, im gonna go start it up and make sure.
well i just restarted it, and started great, and no smoke, hummmmmmm
should i try it again tomorrow ???????????
Ric
Ric is offline
Old 06-24-2004, 07:01 PM
  #87
mike_d's Avatar
na, don't worry, they say that you can use seafoam in the crankcase so you didn't hurt anything. it just won't do the good cleaning of the valves and such since it didn't go through the pcv line.
mike_d is offline
Old 06-24-2004, 07:04 PM
  #88
Ric
Ric's Avatar
woow, now i feel better, ill be able to sleep tonight, lol
Ric is offline
Old 06-24-2004, 08:57 PM
  #89
keisur's Avatar
I smell sarcasm.
keisur is offline
Old 06-24-2004, 09:33 PM
  #90
Mossback74's Avatar
Change your oil
Mossback74 is offline
Old 06-24-2004, 10:36 PM
  #91
96LtdYota's Avatar
i would change it
96LtdYota is offline
Old 06-24-2004, 11:09 PM
  #92
AgRunner06's Avatar
Originally Posted by 96LtdYota
i would change it
Me too.
AgRunner06 is offline
Old 06-25-2004, 12:10 AM
  #93
NX Tacoma's Avatar
Originally Posted by midiwall
and.. I'm back!
The bottom line is that my truck definitely shifts better. 1st->2nd is still "slower than I'd like" but it's definitely faster than it was.
The biggest change came in the downshift into passing gear. It's MUCH better. Quick and positive. $4.59 - another good investment.
This is only after about 7 miles of driving. I'll know more tomorrow after the drive to work.
(a personal disclaimer) I should point out that I know my driving style is such that I should get tranny work done to create a better experience and make my tranny work less. I'm not thinking that SeaFoam is a work-around for what should happen. ...but I like what it did for me.
Ok Midiwall I bought 6 Sea Foam Tune up and 4 Tran's(ordered double of everything). I think I should be set?!?!
NX Tacoma is offline
Old 06-26-2004, 09:34 AM
  #94
NX Tacoma's Avatar
Is this were I can pour the Sea Foam in the intake??
Old 06-26-2004, 09:36 AM
  #95
NX Tacoma's Avatar
Closer pic.
Old 06-26-2004, 09:41 AM
  #96
bamachem's Avatar
See the pic...
Attached Thumbnails Seafoam Injector / Intake Cleaner = GOOD STUFF-pcv2.jpg
bamachem is offline
Old 06-26-2004, 09:44 AM
  #97
NX Tacoma's Avatar
Thanks Bamachem, I will try it now!
Old 06-26-2004, 10:37 AM
  #98
NX Tacoma's Avatar
When I pulled out the hose, my motor stalled. I think I have a problem!?
Old 06-26-2004, 10:40 AM
  #99
bamachem's Avatar
No, it will run like total crap with it pulled. You may need to pinch the hose a little when you do it so not as much air gets in through the hose and leans out the engine...
bamachem is offline
Old 06-26-2004, 10:44 AM
  #100
NX Tacoma's Avatar
How about holding to throddle a little bit?
Quick Reply: Seafoam Injector / Intake Cleaner = GOOD STUFF
