Seafoam Injector / Intake Cleaner = GOOD STUFF
Old 06-22-2004, 06:46 PM
  #41
DavidA's Avatar
Ok, ran it through the 22RE on my '91, runs smoother and seems to rev up faster. Put half the can in the gas tank.
Ran another can through the 3.4 and it also runs a little smoother. Not a huge difference but it is smoother.
The biggest difference was when I put some in the old John Deere riding lawnmower! It is about 14 years old and I have never put any type of cleaner in it. It is running very smooth and seems to be more powerful. Sweet!
Overall I would say worth the investment so far.
DavidA is offline
Old 06-22-2004, 11:56 PM
  #42
midiwall's Avatar
Originally Posted by AgRunner06
Yep, if I remember correctly he used the brake booster hose. Long story short, he sucked it in, hydrolocked his motor, and threw a rod.
Here ya go:
https://www.yotatech.com/forums/show...ghlight=engine
Hell, I don't even know where the PCV hose is on the 3.slow. It would take some searching to find it. Either way, it's not going into my engine.
Just a word of caution.
Okay... But I think that folks should keep in mind that he hydro'd the engine because he let the engine suck it in. What happened is not a fault of the product.
The instructions on the can very clearly say to "SLOWLY pour" it in. (emphasis is theirs)
midiwall is offline
Old 06-23-2004, 05:40 AM
  #43
DrummerDaveB's Avatar
Well, I used this last night. At least the PVC path.
It did blow white smoke for about 15 minutes, but what it did not do is cure my rough/vibration idle issue.
I poured about half the can into about 1/2 tank of gas. Maybe cleaning the fuel system will help some. Or maybe not, but worth a shot.
Maybe I'll get lucky and get another 1 or 2 mpg out of it.
I'll let you know if I see any results from the fuel treatment side, or any other observations.
DrummerDaveB is offline
Old 06-23-2004, 05:58 AM
  #44
calamaridog's Avatar
Clean the MAF/intake.
calamaridog is offline
Old 06-23-2004, 06:16 AM
  #45
bamachem's Avatar
definitely pull the MAF if you haven't yet (use carb or TB cleaner). also, you can change the PCV. pull the hose going to the PCV and cap the hose with your thumb and see if the engine runs smoother. if it does then get a new PCV for $3 and replace it. have you replaced the fuel filter. it's about $30 from toyota and can make a big difference in the fuel supply pressure to the injectors if it's old and clogged. i also assume that you've changed the plugs? did you use denso or ngk? that's the only two that i would recommend. make sure they are platinum, two prong.
too bad the seafoam in the intake didn't work for you. maybe try a strong dose to the tank like i did to clean the fuel rail and injector bodies...
good luck.
bamachem is offline
Old 06-23-2004, 06:21 AM
  #46
good luck.
I've already cleaned the throttle body and replaced the PCV.
I guess cleaning the MAF is on the list, as well as checking the plugs out. Although they were replaced ~25k miles ago. Fuel Filter needs done too.
Just so many things to check/clean/replace. . .
Old 06-23-2004, 06:35 AM
  #47
bamachem's Avatar
the good thing is that they are cheap and easy things to check/clean/replace...
bamachem is offline
Old 06-23-2004, 06:55 AM
  #48
fsudave's Avatar
I think DrummerDave and I may have similar idling problems. So, I am reading this thread very intently. I will try cleaning the MAF, replacing the PCV, and pouring a half can of seafoam in the gas tank for the injectors
fsudave is offline
Old 06-23-2004, 06:56 AM
  #49
bamachem's Avatar
read again and pay a little more attention. it's 1/3 can into the PCV hose and 1-2 cans into the tank...
bamachem is offline
Old 06-23-2004, 06:58 AM
  #50
fsudave's Avatar
Thanks, Bamachem. My mistake
fsudave is offline
Old 06-23-2004, 07:02 AM
  #51
transalper's Avatar
Bamachem, Thanks for inspiring me to do the seafoam treatment! I've used it for years as a fuel addative but have never tried the injector trick. The runner is due for a tune-up and deserves a little TLC.
transalper is offline
Old 06-23-2004, 07:15 AM
  #52
bamachem's Avatar
no problem. anything that can help with MPG's is a good thing.
lol... adding it the tank IS cleaning the injectors. adding it to the PCV hose cleans the AIR intake plenum and intake valves. lol
bamachem is offline
Old 06-23-2004, 07:23 AM
  #53
transalper's Avatar
Roger that.
Old 06-23-2004, 07:25 AM
  #54
bamachem's Avatar
just having a little fun with ya....
bamachem is offline
Old 06-23-2004, 08:31 AM
  #55
Bob_98SR5's Avatar
drummer,
correction to what bama advised re cleaning MAF w/ throttle body or carb cleaner: do not use either. use an electronic wire 'contact' cleaner to clean the MAF wire sensor.
bob
Bob_98SR5 is offline
Old 06-23-2004, 08:36 AM
  #56
bamachem's Avatar
Really? Does the TB/carb cleaner leave THAT much residue? I just use TB cleaner in a spray can a spray the hell outta it then wipe it VERY CAREFULLY with a Q-tip.
bamachem is offline
Old 06-23-2004, 09:10 AM
  #57
I think I'll do what Bob says, as I dont want to accidentally screw up my MAF.
Better safe than sorry.
Old 06-23-2004, 10:08 AM
  #58
loosehead's Avatar
To add to what Bob said, they changed the design of the MAF for '99+ models. '96-'98 have the type that is inside a little plastic "bulls-eye" looking shell, where the '99+ is the exposed-wire type (I think...).
loosehead is offline
Old 06-23-2004, 11:12 AM
  #59
96LtdYota's Avatar
on the can of sea foam it says that it can be put into the crankcase with the oil. Um i woudnt know if it would help, and i cant imagine it being good for the parts. I could see it being good if you were to run it in there for 5 minutes then change out your oil afterwards. Lemme know
thanks
96LtdYota is offline
Old 06-23-2004, 11:54 AM
  #60
4runner4me's Avatar
If added into oil how long should you run it.
4runner4me is offline
Quick Reply: Seafoam Injector / Intake Cleaner = GOOD STUFF
