Runs great for 5-10 minutes and suddenly dies?
Hello everyone, I hope that today shines bright on your yotas.
I wish it was shining on mine. It started hard this morning and ran for about 15-20 minutes then stalled. It started right back up again and ran for 5 minutes, again it stalled. I drove it about a mile and it seemed fine. Went out to run it again so I could have heat. Died after 10 minutes Started right back up and I drove it home where as I stopped to back into my driveway it died again. Started right up again and I backed up to my trailer. The truck is a 97 T100 3.4. Anyone else ever had this problem, and if so what did you have to do to fix it? Open to any and all suggestions. Thanks in advance for your help and ideas. Safe toy travels to you all.
Return message on fuel problem post.
I replaced the wrong plugs that were in the truck with factory Denso double element plugs. Just put them in about 3 months ago or 3000 miles ago.
Sounds like bad chip 1st debank fried like wore out wire insi
Reply from person who talked about bad chip
Reply. I read your response and I don't know what happened to the rest of it but I didn't get to see it all. You mentioned a bad chip and bleed through on board? Check what sensors? What was the rest of your reply?
