remove the ignition key cylinder? (pics inside)
Old 02-15-2006, 02:50 PM
shazaam's Avatar
guys I finally went to pull the car out of the garage today and the steering wheel is locked. The car starts right up, and shifts into drive. But the steering wheel remains locked. Any ideas on what I did wrong or missed?
thanks
Old 02-15-2006, 02:56 PM
admiral's Avatar
there is a solid bar that goes from the ignition switch too the steering column. The steering columng has a notch where the bar goes into. You are probably missing the pin that unlocks this bar. I am going to look around and see if I can find diagrams of the ignition switch.
Old 02-15-2006, 03:01 PM
NorCalVP's Avatar
thanks
In the top pic where you have the broken Cyl, Does that shaft all the way to the left go back in? Is there a chance it went in backwards? Chance that anything went in backwards or upside down?
Old 02-15-2006, 03:06 PM
shazaam's Avatar
in this picture
the cylinderical piece on the left inserts into the back of the lock cylinder and then on the other end inserts into the grey piece in the center of the pic below. I guess this piece could be inserted one way or flipped 180 degrees and inserted the other way. Other then that everything else was pretty straight forward.
Old 02-15-2006, 03:09 PM
  #25
shazaam's Avatar
I'd appreciate the diagram, b/c I dont recall seeing any pins
thanks
Old 02-15-2006, 03:44 PM
  #26
admiral's Avatar
Ok I found the diagram. but the file is too large to post. I am wrong about the pin. I have a whole PDF file, on the steering column if you want I can send it to you. It would help you find the problem, much easier.
Old 02-15-2006, 03:57 PM
  #27
shazaam's Avatar
sure .. email it to sdastg1@hotmail.com
thanks
Old 02-15-2006, 04:02 PM
  #28
admiral's Avatar
Ok, I have sent you the PDF files, I hope they work.
Old 02-15-2006, 04:25 PM
  #29
shazaam's Avatar
got it .. thanks .. I'll flip through them tonight
Old 02-16-2006, 01:07 AM
  #30
91 4Runner's Avatar
Could you send me the same, as the key got broke off in the cylinder on mine as well. For me it's just a PITA more than anything else... 1 key to unlock and 1 key to start... Thanks...
Old 02-16-2006, 08:04 AM
  #31
shazaam's Avatar
ok I went and tried to switch the inside cylinderical piece around .. and when I do the car won't start .. so I have that piece inserted correctly. So that's not it
Old 02-16-2006, 08:25 AM
  #32
shazaam's Avatar
admiral -- I'm looking at the pdf file you sent me and the only thing I can think of that I see on there is a "key interlock solenoid" .... is this what your refering to?
Old 02-16-2006, 10:02 AM
  #33
admiral's Avatar
If you take a look at the part where the ignition switch assembly attachs to the steering column. In there is the metal bar I am talking about. The ignition switch assembly has this thing that looks like a cam, that goes from the key lock to the electric switch. When you turn the key this cam moves that bar out of the steering column. Oh this thing is spring loaded if the spring is not in there it is not going to move.
91 4Runner , Sure Ill send you the PDF files I actually have a whole manual for hour 4runners on PDF. Just tell me where you want me to send it to.
Old 07-14-2011, 01:23 PM
  #34
David_Y's Avatar
I have the same problem with a key that wont turn and a locked steering wheel. I have a new ignition lock tumbler ready to install but am concerned that the wheel wont unlock when i remove the stuck key tumbler. Did your steering wheel unlock when you removed ignition tumbler?
Old 06-02-2017, 02:44 PM
  #35
Tiredofnewemails01's Avatar
Need help. Please!!!
could you please send me a copy as well? I have a 2002 tundra 2wd 8 cyl that has the ignition locked not turning to acc, so I nee to replace all of the whole assembly since I can't remove cylinder without key turning to acc. Any help is greatly appreciated. My email: tiredofnewemails01@gmail.com
icentropy
09-16-2020 02:47 PM
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
cars-guy
07-11-2015 07:51 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: remove the ignition key cylinder? (pics inside)
