Power-train overhaul & 4x4 conversion (Sunrader RV)
Old 06-27-2013, 06:20 PM
Sunraderswap's Avatar
Moderators - This is probably in the wrong place, and if so please move it.
The short version: Looking for thoughts related to axle upgrades and swapping in a 4.0 lexus. Thanks for looking & constructive criticism appreciated
I recently purchased a 77 Sunrader RV -the solid fiberglass one, not because I particularly needed it but for a steal at $1400. The 20r was swapped out for a 22r what I assume was 100k ago and the axle was upgraded from the five bolt to a full floating 6 bolt. After digging in a bit more, I realized that not only is the 22r under-powered for this when its in good running condition, but I only have 20psi compression in cylinder 3, the clutch is going out and the transmission has a bad rear seal and the 2wd barely has enough traction to make it up my steep a$$ gravel driveway. So, basically it is a good thing I enjoy projects.
I have been debating on swapping in a Toyota diesel , a vw 1.9, a 4bt, but I think that the 4.0 is the ticket considering I can get a ls400 with 80k miles for $500 with the wiring and ecu. Does anyone have any experience with these motors in a truck? What kind of mpg would I be looking at?
This is also a 2wd but I spend way too much time in cascade snow with a disdain for chaining up, so a 4wd conversion is definitely in the plan.
I was thinking I could get a pre 86 4wd 5 speed truck with a bad motor ( a few on the local craigs for around $1300) and swap the front drive train and suspension into the sunrader, while mating up the 4.0 to the 5 speed.My concern is that the weight may be too much for the stock front axle (in spite of the rear weight bias)net weight around 5600+ supplies. I have also heard that swapping in fj axles are the better option, but that decreases the cost effectiveness of buying a truck with a bad engine, but allows a conversion to srw.
This will be a project for next summer (assuming the engine holds up till then) but I would like to hear potential pros and cons.
Old 12-26-2013, 01:15 PM
magentawave's Avatar
Did you make a decision about what to do with your Sunrader? I have an 82 Sunrader that I'm totally rebuilding and was wondering if its possible to retrofit it with a 4x4 front end? Someone with a 4x4 Sunrader told me that the two wheel drives go pretty well offroad if I installed a lock in the rear axle so I'll have posi-traction. I guess the parts cost about $500 at LC Engineering.
Old 12-26-2013, 04:34 PM
donomite49's Avatar
I can't believe no one has offered advice, opinions or even a response untill now.
Yotatechers asleep at the wheel?
I think a yota 4x4 motorhome would be cool..pics?
Old 12-27-2013, 08:10 AM
wyoming9's Avatar
Red face
I think it would be a bunch of work .
Now if you put no value on your time because you will have quite a bit .
What you want to do can be done if that is the main reason .
Find a rear ended 4x4 Tundra .
Splice the frame somplace behind the transfer case mount
match up your gear ratios 4x4 V8 camper
Fabricating body mounts and steering linkage will be much easier then doing a engine swap and converting to 4x4
The fact it is a 77 I wonder just what all else needs replaced??
coleypull15
11-03-2015 07:41 AM
PNWrider
10-30-2015 08:14 AM
defrag4
07-31-2015 10:50 AM
PopsDad1
07-30-2015 02:21 PM
pyramid
07-29-2015 06:53 AM
Quick Reply: Power-train overhaul & 4x4 conversion (Sunrader RV)
