permatex RTV sealant
Old 03-31-2012, 09:50 AM
Brendan's Avatar
i'm using RTV sealant between the rear diff carrier and housing and am unsure how tight to torque the studs. the sealant says to finger tight while it's still wet and then turn 1/4-1/2 turn after one hour. it also mentions that it will be fully dried after 24 hours, but no mention of tightening any further. the torque spec is 18 ft-lbs IIRC, but this is when using a gasket.
1/2 turn beyond finger tight seems pretty weak to me. any thoughts? thanks!
Old 03-31-2012, 10:29 AM
Mandy Tuning's Avatar
next day torque as per manual and add fluid.im always in hurry so i torque after few hours and add the fluid never got a leak
Old 03-31-2012, 11:52 AM
MudHippy's Avatar
The FSM, as well as showing you where to use it, tells you how it should be used. Basically...You apply it where specified, in the bead size recommended. Then assemble the parts, installing the fasteners to the recommended torque, within the time frame allowable(within 5 minutes). Done.
From the FSM regarding the application of FIPG:
HINT: Avoid applying an excessive amount to the
surface.
• Parts must be assembled within 5 minutes of
application. Otherwise the material must be re–
moved and reapplied.
It doesn't tell you to do what RTV manufacturers tell you to. So I don't do what they say, I do what the FSM says.
Usually...but in this case I don't. Because I use RTV for sealing differentials too. Where the FSM says to use a gasket instead.
Old 03-31-2012, 06:14 PM
Brendan's Avatar
thanks. got everything up and running without leaks. some of the studs won't tighten though. they're in the housing threads, but somehow they don't tighten
Old 03-31-2012, 09:19 PM
BMcEL's Avatar
Should have replaced the studs with bolts while you were in there...common issue for them to pull out of the housing.
JUICE222
10-13-2015 08:50 AM
tonkatruck_79
08-30-2015 06:13 PM
Snort
07-19-2015 07:03 AM
Dave Mooney
11-23-2005 10:43 PM
brendonv
08-29-2005 09:01 PM
Quick Reply: permatex RTV sealant
