painting wheels
Old 06-20-2006, 01:15 PM
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
painting wheels
I am not sure exactly what material these wheels are but I want to paint them black. I love the look of my truck when I have the black steelies on with the MT/Rs and I want to keep that same look year-round. The seller lists them as alloy wheels. The pictures are located here: https://www.yotatech.com/forums/show...446#post900446
my question is, can anyone tell what I need to do to paint them? Sand them first? prime them? what kind of paint? Thanks!
Old 06-20-2006, 06:03 PM
Cebby's Avatar
I used Duplicolor Wheel Paint. Simple to use.
For prep, I used an aircraft stripper to get the clearcoat off. Then I wet sanded them with a 320 grit 3M sanding sponge. Painted 2-3 coats of the Duplicolor Wheel Paint. I did not use clear since I figured these will be getting touched up when they get beat up from wheeling.
I did silver:
Old 06-20-2006, 06:26 PM
rimpainter.com's Avatar
VHT makes a Polyurethane wheel paint that works awesome. Here is a thread I started a long time ago. There are many other threads like this as well.
https://www.yotatech.com/forums/show...ight=oem+black
Old 06-20-2006, 07:55 PM
4runnermt's Avatar
Just make sure you remove all of the clear, or else they will look like crap.
Old 06-20-2006, 08:10 PM
midiwall's Avatar
When I did my alloy's, I started with a 4" coarse wire wheel in a drill motor and got all the gunk off that I could. One nice side effect of that is it took out a lot of the road rash.
Then a coat of Rust-oleum primer; then two coats of Rust-oleum flat black.
You can see the results here: (click for a larger pic)
Did you try searching? There are a couple of threads on this...
chukarhunt
12-08-2019 11:39 AM
Jcrawl94
10
10-24-2015 04:34 PM
BeMiceElf
10-10-2015 09:40 PM
ViperTT
08-14-2015 05:27 AM
58rennur4
08-04-2015 08:49 AM
Quick Reply: painting wheels
