View Poll Results: Which filter
Purolater Pure One
68
11.60%
Amsoil Super Duty
48
8.19%
Toyota OEM
255
43.52%
Other
215
36.69%
Voters: 586. You may not vote on this poll
oil filter poll
Old 08-04-2004, 05:51 AM
  #61
jataga's Avatar
Fram Oil filter.
Change oil every 3K miles
Been changing every 3k miles since I got my 4Runner.
Now sitting at 138,000 miles.
Lots of oil changes. : )
Running just as good as the day i got her!
-JOhn
Old 08-04-2004, 08:53 AM
  #62
MvCrash's Avatar
How big is a Micron?
Old 08-04-2004, 09:02 AM
  #63
amorphous's Avatar
i started out with the Mobil 1 filters....but they are pricey.....So, I'm using the Bosch filter now...no compliants...no problems....
Å
Old 08-04-2004, 12:55 PM
  #64
CynicX's Avatar
there is about 25,400 microns lined up in one inch....
Old 11-05-2004, 11:00 AM
  #65
TBob's Avatar
he's my write-up on what I run
https://www.yotatech.com/~corey/tech...msoil/tbob.htm
Old 11-05-2004, 11:23 AM
  #66
4Runner4Christ's Avatar
Amsoil Super Duty every six months or 12,500 miles (normally six months as I put about 10K miles every six months).
Old 11-05-2004, 06:25 PM
  #67
rangerhawk's Avatar
Here's a link to paradise garage....http://neptune.spacebears.com/cars/s.../oil-life.html
They are, at present conducting an ongoing real-world study of the effectiveness and how long synthetic oil will last. They have set certain parameters on each syn oil they use, change the filters at set intervals, run chemical analyses on the oils at set periods (I think weekly) and then post weekly updates on their findings.
Its been very interesting and informative. They have already finished the testing on Mobil 1 and are now in the Amsoil testing process. They top off constantly when oil is low, test for particualtes, metals, viscosity and other data.
One interesting finding so far with the Mobil 1 was that it became a better lubricant after 3,000 miles and seemed to work better.
Check it out. Its been an interesting study to follow. Combined with bob the oil guy I've learned alot about syns.
Old 11-05-2004, 06:29 PM
  #68
914runner's Avatar
Well the motor has about 45,000 on it now lol and im still using the Napa Spin-Flow filter and 10/30 or 10/40 dino oil!
Old 11-05-2004, 06:30 PM
  #69
PirateFins's Avatar
mobil drive clean dino and oem toy filters until the 2 cases run out.
Old 11-08-2004, 04:38 PM
  #70
EricM's Avatar
Toyota OEM and Castrol GTX 5W-30
I used to do all of my vehicles on 2K intervals, but decided to go with 3K intervals on the 4Runner since it's a pain to unbolt the skidplate for the filter. I'll switch to 5K intervals when I hit 15K (next oil change) since the oil still looked pretty clean this time.
I notice that Toyota filters are now made in Malaysia... the first couple I bought were made in Japan.
Old 11-15-2004, 04:50 PM
  #71
87TurboYota's Avatar
For my the car I've owned for 4 years now which is my first and all
my families daily drivers I change their oil and use Pennzoil with
Puralator filters and try to do it before 3,000 miles. I haven't had any engine problems with any of them. But they are all American made cars. I just bought this Toyota truck and wondering why nobody uses this combination
or atleast not Pennzoil in their yotas.. I've heard a lot about Amsoil.. How
much does it typically cost? Thanks.
Old 11-15-2004, 04:59 PM
  #72
evilcow's Avatar
I use either Toyota, AC Delco or Motorcraft. It all depends on whats available. Never Fram.
Old 11-18-2004, 08:55 AM
  #73
ranma21's Avatar
I have been using Mobil1 5w30 and Mobil1 filter and change oil every 6k miles. I have been using that combination on my 92 Accord for the past 4 years topping 130k, right now the car has 240k miles and it still run like a 80k honda with no oil leak whatsoever, not even a drop anywhere near the oil pan. I am using amsoil series 2000 and amsoil filter on my other Accord and my 4Runner. Have put 8000++miles on my runner, oil still look pretty clean..so far so good!!
Old 11-18-2004, 08:01 PM
  #74
I use OE or purolator filters w/ chevron supreme 10/30 at 5k intervals. 310k miles....hmmm
Old 11-18-2004, 09:49 PM
  #75
Brew's Avatar
Nothin touches my 1991 4x4 pickup except Mobil 1 10w30 and Toyota OEM oil filters. Truck doesnt burn a lick of oil...looks the same after 2500 miles as the day I poured in from the bottle.
Expensive, but I get the oil for free
Brewsky
Old 11-19-2004, 06:01 PM
  #76
George4door's Avatar
I run Valvoline full synth 10w30 and Ive been trying different filters (mobile one, OEM, Fram tough guard...). And change every 4500 miles or so.
If you are running dino oils than you should change your oil every 3000 miles or so, but on synthetic you can go maybe 7000 without any adverse viscosity breakdown IF you have a the proper filtration or change filters. (with some oils in my Integra I could actually tell the viscosity had lowered it felt thinner when I drained it)
With japanese engine tolerances being so tight, midway through the engine life cycle there really much debris to be filtered (comparativey to other engines) My oil comes out at 5000 miles very clean (and I drive hard), despite wich filter I use.
I might stick with OEM, I havent seen any advers oil affects from it. Or just keep switching it.
Old 11-19-2004, 09:17 PM
  #77
Mobil 1 10w30 synthetic with a K&N oil filter
Old 01-03-2005, 01:37 PM
  #78
X-AWDriver's Avatar
I run this combo also but if K&N isn't available I like Purolator PureOne filters.
Old 01-04-2005, 06:52 PM
  #79
88-4RUNA's Avatar
i use bosch filters on my vehicles
Old 01-06-2005, 06:26 PM
  #80
Darryl's Avatar
Syn-oil
I'm pure one and Castrol syn every 3-5K on my 87 4x4. My guess is I'm wasteing a lot of money. I had a car that I switched at 100K to castrol syn 5w-50. It was a car I preferred to die so I only changed oil and filter once per year at 15-20k. My plan was to be sorry and kill it. At 310,000 I parked it with no engine problems and a quart between changes.
Quick Reply: oil filter poll
