Misfire after engine cleaning
Old 07-22-2006, 08:11 PM
bmwpower's Avatar
So I cleaned the engine today (simple green and water). After cleaning, I'm getting what sounds like a misfire.
I pulled off all of the plug ends to see if there was water down the holes. Nothing. I'm going to take a look at the MAF and give it a cleaning.
Anyone know what the problem might be?
Old 07-22-2006, 08:25 PM
ebelen1's Avatar
I know you checked the plugs for water but that's what happened to me when I first got the truck. Decided to get a detail and they blasted the motor w/ water and it would idle funny. They tried blowing compressed air into the spark plug areas but to no avail and eventually a CEL (didn't look up the code). After we swapped in new plugs, no CEL and it ran great.
BTW, you didn't get water into the airbox, did you?
Old 07-22-2006, 09:40 PM
bmwpower's Avatar
No water into the airbox. I just shot carb cleaner over all the hoses to see if there was a vacuum leak, but to no avail. Cleaned out the MAF with electrical spray - no luck.
I tried putting my code reader on the truck, but the darn thing isn't being detected!...figures. And I need the truck by tomorrow morning, 10:30. I think I may be screwed.
Old 07-22-2006, 09:54 PM
msw0085's Avatar
i had the same problem with detailing my engine. I replaced the plugs and wires and solved the issue.
Old 07-22-2006, 10:54 PM
bmwpower's Avatar
Looks like I'll try and replace both the wires and the plugs tomorrow morning. I'll let you know what happens.
Thanks!
Old 07-23-2006, 09:35 AM
NC-B17A's Avatar
check your dist cap. The seal around mine was cracked & let water leak in the cap.
Mine would missfire when I washed the motor.
Old 07-23-2006, 10:40 AM
L33T35T 4Runner's Avatar
if he has the 3.4, he doesnt have a distributor
Old 07-23-2006, 12:04 PM
bmwpower's Avatar
New plugs and wires fixed it. 2 of the plugs had a little water in the holes, even though I blew the heck out of them with the air hose. Go figure. Thanks guys!
Old 07-23-2006, 01:47 PM
Adam F's Avatar
This happens to me every once and a while. Just driving around for 15 minutes or so will dry things out and fix the problem.
Old 07-23-2006, 02:44 PM
ebelen1's Avatar
You were lucky or you didn't have as much water in the holes. I drove the truck around two days sputtering after blowing compressed air in the spark plug holes to no avail. I guess it dried up after a few days but the plugs were all messed up and needed to be replaced...
Old 09-16-2008, 06:58 PM
postalxj's Avatar
Iknow this old but this just happened to me on mt 01 SR5
I put a code reader on it and it showes a #6 cylinder miss fire a just checked all of the plugs and no water so i guess im going to get new wires and plugs and try that just hope on of the coils is not bad
Do any of you know what cly is #6
im still learing the Toyota
smthwsn357
05-01-2024 07:28 AM
icentropy
09-16-2020 02:47 PM
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
razorman8669
07-12-2015 12:13 PM
Quick Reply: Misfire after engine cleaning
