Leak on rear axle but from what???
I have a 1996 Toyota T100. Saw this leak on the rear axle on the drivers side but do not know the cause. Shock looks fine but old. Brakes feel fine and reservoir fluid looks fine.
Thanks for looking and some ideas.
looks like it is leaking from the brake line clip. The bolt that holds the clip in the axle housing. Maybe take out the bolt and take a look. Then clean it off and reinstall that bolt with some blue loctite. Thought being the leak is comming from the hole the bolt is in perhaps. The loctite will act as a stop leak?
FS[PacNorWest]: Rear chromoly axle shafts
A2theK
01-10-2016 10:18 AM
jerusry
10-19-2015 05:28 PM
Avenged
07-09-2015 07:55 AM
