Interesting Resistance Readings on Plug Wires
Old 03-13-2010, 03:01 AM
24Runna's Avatar
Was testing the resistance on my NGK wires and found the results interesting.
5 - 9.1 6 - 3.3
3 - 8.2 4 - 3.1
1 - 7.1 2 - 2.9
Coil - 2.9.
Word to the wise, my contacts on the coil cable were so bad I didn't even get a reading at first, looks like the dielectric grease hardened. Hopefully this solves my idle issue and my gas mileage too!
I actually expected them all to come in around 8, but then i was like dur, those left bank is much longer cord.
Old 03-13-2010, 06:55 AM
tc
tc's Avatar
Note that if your plug wires have carbon cores, they will wear out and need replacement periodically.
If they have actual wire cores, they will last much longer.
Old 03-13-2010, 07:58 AM
mt_goat's Avatar
TC, any tips on how to tell what the core is?
Old 03-13-2010, 06:55 PM
tc
tc's Avatar
The box, but I forget which is which ... I think if it says RF suppression, they are metal, and should have a shielding wrap around the core. If they are carbon, they likely won't have that shielding wrap.
Old 03-13-2010, 07:21 PM
24Runna's Avatar
Hmmm, Thanks for the tip. I'll have to check the NGK's,they only have 30k or so miles.
OT, but is unusual that the OEM wires are $120?
smthwsn357
05-01-2024 07:28 AM
MO transplant
04-23-2023 11:58 AM
icentropy
09-16-2020 02:47 PM
smiley52
07-11-2015 05:16 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Interesting Resistance Readings on Plug Wires
