How fast can I go with 4.70 tcase and 4.88 diff gears on 36" IROKS?
Old 11-20-2014, 12:59 PM
Double D's Avatar
Its has been probably two years since I posted in YT. I am about done building this 88 pickup. I ordered the trail-gear 4.70 tcase and 4.88 detroit locked differentials.
If you have or had this setup, can you please shed some light on what my top speed might be? How do you like this setup? etc...
Here are a couple of recent shots. Fiberglass hood, steel plate fenders, and bed panels coming soon.
Size:  94.5 KBName:  20141025_121838_zpsc3012f4e.jpg
Old 11-20-2014, 02:53 PM
Stu Pidasso's Avatar
I suppose you should figure out how far one revolution of your tires moves your truck. Then next figure out how many RPM you are willing to run your truck at. Divide that number by your final drive ratio. Then multiply that figure times how far your tires move the truck in one revolution of the hub.
I personally do not run my truck over 4k rpm. You may choose to do different than I do and that is fine. I have never bothered figuring out my top wheeling speed. A friend of mine was running 470's in his case. Seems like 2mph was top speed but I do not remember his tire size.
Old 11-20-2014, 03:15 PM
Double D's Avatar
Thanks Stu! Now to find that transmissions gear chart! I was hoping to NOT do the long math route but I guess it will do.
Old 11-20-2014, 03:23 PM
JasonYota's Avatar
Look at grimjeeper website for their gear calculator.
Old 11-20-2014, 03:38 PM
Double D's Avatar
Thanks Jason!
I just wanted to add this link. Found this thread looking for gear charts and it is a BIG insight on running different gear setups between tcase and diffs.
https://www.yotatech.com/forums/f115/4-70-transfer-case-gears-169431/
Old 11-20-2014, 03:44 PM
560.5 revolutions per mile on 36" tires.
Old 11-21-2014, 05:00 AM
muddpigg's Avatar
https://www.marlincrawler.com/differential/complete
Should give you an good idea.
Old 11-21-2014, 12:09 PM
wyoming9's Avatar
Red face
120 feet /second in free fall rolled out the back of a C130
Old 11-21-2014, 01:33 PM
Double D's Avatar
Lmao. I guess terminal velocity is fast enough for me in a jacked up yota!
Old 11-21-2014, 02:19 PM
muddpigg's Avatar
polo451
13
11-20-2016 07:49 PM
jerusry
10-19-2015 05:28 PM
deepmarsh
08-06-2015 03:44 AM
jaretstuff
08-04-2015 02:08 PM
yourrealdad
07-29-2015 11:08 AM
Quick Reply: How fast can I go with 4.70 tcase and 4.88 diff gears on 36" IROKS?
