Fuel Injector Cleaner
Old 05-30-2003, 04:27 PM
Paul H.'s Avatar
What fuel injector cleaner do you use to clean your injectors and do you feel that it does a good job? I have tried some and have noticed no improvements after using them.
Old 05-30-2003, 05:02 PM
Victor's Avatar
BG44K from the stealership. $21 but well worth it.
Old 05-30-2003, 05:05 PM
rimpainter.com's Avatar
I have used every kind in various vehicles, Chevron, STP, Gumout, etc. Never noticed a difference.
I figure it this way, if your gas mileage isnt bad, and you dont notice a difference, you just poured x dollars down your fuel tank.
Over on the Maxima boards, a couple guys figured out that too much use of this stuff (over 3 bottles a year) will eat the o-ring on the injectors, causing injector failure.
Old 05-30-2003, 05:09 PM
Victor's Avatar
I use BG44K every 20-25k miles
I wonder if it is supposed to be used every 44k?
Old 06-02-2003, 08:17 AM
tom_993's Avatar
I like "Lubro Moly Jectron" and "Lubro Moly Ventil Sauber." Use a can of each in the same tank of gas, and drive it Italian tune-up style!
Tom
Old 06-02-2003, 08:34 AM
TDiddy's Avatar
Wow, I never would have thought of that. Good to know.
Old 06-02-2003, 08:59 AM
dusty98's Avatar
I use Redline S2, its about $6 delivered to my door. Gas mileage in my high mileage 2nd generation went up considerably after using it.
I purchased two bottles; used all of the first one for initial cleanup, then periodically use a portion of the 2nd bottle for maintaining.
Old 06-02-2003, 09:10 AM
runningman's Avatar
Post
Go with Forte Fuel Injector cleaner. Awesome stuff. A little pricy but well worth it (once a year only)
Old 06-02-2003, 09:19 AM
Away
Dr. Zhivago's Avatar
I use Redline S2 when I think about it.
Dr. Z
Old 06-02-2003, 10:03 AM
keisur's Avatar
I use that Outlaw crap.
Old 06-02-2003, 01:01 PM
rjm
rjm's Avatar
injectors
use redline s1. 4.50 a bottle- i have used it in all my vehicles for years. i have never had my injectors cleaned- they never need it
Old 06-03-2003, 03:28 PM
Paul H.'s Avatar
Golden or Dr. Zhivago, where do you buy your redline?
Old 06-03-2003, 04:08 PM
elnip's Avatar
Re: injectors
Me too. It really made a difference in my '86 Celica. I use it in my truck at every fill up.
Old 06-04-2003, 04:50 AM
keisur's Avatar
Desert Rat has it.
Old 06-04-2003, 06:09 AM
2001Millrunner's Avatar
mix some jet fuel:tomcat:
Old 06-04-2003, 06:39 AM
dusty98's Avatar
I purchased mine straight from them. I had called to find a distributor and the lady took my order then. Here's the website: http://www.redlineoil.com
Old 06-04-2003, 07:03 AM
pfdaxe's Avatar
I always used Cheveron/Techron in my Porsche and noticed a big differance. Haven't noticed as much on the Runner though.
But then again. The Porsche had about 150,000+ miles on it.
Old 06-04-2003, 02:15 PM
I tried the Chevron stuff recently and noticed a minimal improvement, though at 85k miles I kinda expected more to be honest. I'm going to try the redline stuff later after I change the fuel filter out.
OOC, and this may be because I don't know how to interpret those readings, why should you change your oil within 500 miles of using injector cleaner as someone suggested? Does it get past the rings into the oil or what?
Old 06-04-2003, 03:01 PM
Away
I buy mine from a local parts store, Baxter Auto Parts. I think it's about $6.00 a bottle.
Peace!
Dr. Z
Old 02-10-2010, 09:45 AM
ahoier's Avatar
I tried the Chevron/Techron stuff from wally world. It was strange, I don't normally go through a lot of gas, so the fill of fuel sat in the tank maybe a week or two. But half-way through the tank, I was sitting at a red light, and my CEL went on.
I rode around with the CEL on for a day or two. I was on my way to Advance to get it read, and I gunned it (WOT) on the on-ramp/merge lane on the highway, and off went the CEL.
Think the Chevron hit something loose, triggering the CEL, and then "gunning it" burned whatever foreign substance was there, up? lol.
That's my theory anyways....I'm tempted to take it there anyways and see if the code is still stored...but would feel like a dumbass since it's going on like a month now with the CEL off.
But I've used nearly everything in the vehicle, Seafoam, Warren Autoguard, B-12 CHEMTOOL, etc. Not all at once.....but like 5000mi. between each other. I'd just buy what was at hand. Hell, the warren injector cleaner was only 1$ at dollar tree, bottle said good for 5k (which don't totally understand that, cause after a couple tanks of gas, the cleaner is gone.....lol- so I wonder how they base that time frame).
Quick Reply: Fuel Injector Cleaner
